Rookie Question - R4 Valve Stems?
/ Rookie Question - R4 Valve Stems? #1
TalonDancer
I went to check the air pressure in our new GL3240's R4 tires and...
the valve stem was on the inside of the rear tires????
Is this normal? And why?
TIA - Talon Dancer
/ Rookie Question - R4 Valve Stems? #2
The wheel can be turned around and mounted on the other side(of tractor) for more or less width between the tires and the stems would then be on the other side.
2010 New Holland Boomer 8N (A62613)
2010 New Holland...
Kinze 3600 Wiring Harness (A65640)
Kinze 3600 Wiring...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
Murray Explorer Go Cart (A65640)
Murray Explorer Go...
Winchester 20 Gun Safe (A65579)
Winchester 20 Gun...
