Rookie Question - cleaning hydro filter
   / Rookie Question - cleaning hydro filter #1
c-and-a
Massachusetts
BX2350
Manual recommends using a "non-flammable solvent" - I am sure I am overlooking the obvious, but what are people using...?
I am having no luck finding anything "non-flammable"...
Feedback appreciated
   / Rookie Question - cleaning hydro filter #2
The non-flam business is to protect Kubota in case somebody uses gas, while puffing away on a cigar... If you use gas, which works very well, avoid combustion. If gas seems unsafe, there are non-flam solvents at auto supply stores. Dave
   / Rookie Question - cleaning hydro filter #4
Using a flamable solvent (like gas, which is what I would use) will not harm the filter. It is just a health and safety thing like dwenham said.
   / Rookie Question - cleaning hydro filter #5
The filters are not that expensive-just replace them-that's what I do
   / Rookie Question - cleaning hydro filter #6
Technically, water is a non-flammable solvent (well, except in the presence of pure alkali metals like sodium, potassium, lithium, etc.). Not a very good choice here though. Except for the brake parts cleaner, most non-flammable solvents seem to work about as effectively as water. So I wouldn't let that drive the decision on what to use, unless you don't think you can be trusted with flammable solvents. Kerosene works pretty well too, is cheap and abundant, and not as dangerous as gasoline. I keep a can of original formula Gunk Engine Cleaner around for little jobs... added benefit is you can flush the part completely clean of solvent with running water (due to the emulsifiers) and let it dry completely, whereas most other petroleum-based products are just like... well... mixing oil & water.
   / Rookie Question - cleaning hydro filter #7
I think he is talking about the suction strainer.
Just douche it with brake cleaner.
Swamp Buggy (A49346)
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2011 BMW 5 Series 550I GT Sedan (A50324)
2011 BMW 5 Series...
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
