roof size
   / roof size #1
plastikosmd
could i drag someone off the couch to go measure the roof size on the cab model 3xxx series? need length and width..thank you!
   / roof size #2
Approximately 58 long x 46 inches wide. Now I got to know why I got off the couch to go outside in the cold to do that???
Sincerely, Dirt
   / roof size
thanks Dirt, few hundred bucks later and this is why...windham cab off of a jd9xx series..was too big for that machine...with some modification it should work well on my 3320. came with doors, sliding windows, heat/thermostat/wiper etc..my roof is close to yours. instead of putting cab in front of ROPS I may alter the ROPS (i know, i know) will have to get the forklift out and see what fits. also have the backhoe coming, so that will alter the fit.
   / roof size
agreed, tho it will require some alteration. but for the price it is a heck of a starting point. depending on how it fits..i may just make up the difference in lines with some sort of flexible moulding, something thick, that the cab would set on. i can add and remove metal as needed..just the contours..esp on the fenders etc is where a lot will have to be done. I dont see how it would set between the seat and the ROPS as the seat is under the ROPS. The ROPS is quite high, and I may just lower it..setting the cab over it. Doing that will move the cab back 4 inches..which may effect how it sets on the fenders or where the front ends up. If I do this, and it is to short in length (setting on the steering wheel) I will have to alter the front and move the posts foreward. This of course means the doors will not shut as there will be a gap in the rear. etc. well hope to trial fit this weekend so I know which way to go. Then electric to lights/wipers, and plumb the heat lines as they get coolant from the motor..etc
2014 Ford F-250 Ext. Cab Pickup Truck with Liftgate (A55852)
2014 Ford F-250...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
Giyi 77" Sweeper (A53316)
Giyi 77" Sweeper...
2007 Oshkosh S-Series TMMB 11 CuYd Front Discharge Concrete Mixer Truck w/ Tag Axle (A55788)
2007 Oshkosh...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
