Roof Ridge/Cap Wind Driven Leak
   / Roof Ridge/Cap Wind Driven Leak #51
My concern with insulation stuffed into the ridge vent is that once it gets wet, it will remain wet and cause other issues, like rust to form.
   / Roof Ridge/Cap Wind Driven Leak #52
It won't cause rust if it's only in there for a few months. Won't be any wetter than if it had snow on it all winter.
   / Roof Ridge/Cap Wind Driven Leak #53
There is supposed to be an rubber insert under the ridge cap. At least there is on my buildings. But their outbuildings and not a house. My ridge is not vented. I have no idea how they keep moisture out of a vented metal ridge.
I've seen them blow off in high wind areas.
   / Roof Ridge/Cap Wind Driven Leak #55
Seen what blow off?
Mine had foam things on the inside that blocked water. They sealed any irregular spaces during installation is what I figure.
   / Roof Ridge/Cap Wind Driven Leak #56
You're saying that the foam blew out from underneath the ridge cap? If it did, you either had an inferior product or a poorly installed one. If the vent foam is installed correctly, pinched between the ridge cap and the roof, the ridge cap would have to blow off in order for the foam to blow away.
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
SKID STEER ATTACHMENT MAINTAINER BLADE (A58216)
SKID STEER...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2012 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2012 MACK CHU613...
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
