roof compleated
/ roof compleated #1
Army grunt
Platinum Member
Georga
TC 30 Newholland
/ roof compleated #2
Excellent job grunt and thanks for the pics. I've always wanted to watch a sawing operation like that first hand but it's looking like the closest I'll ever get is my 9" delta shop band saw with a 3/8 blade.:D
/ roof compleated
I have a lot of cutting to do over the next few mounths ill look into a vido.
Army Grunt
/ roof compleated #4
Nice looking building and setup, kimda unusual design. Electric hoist and beam are big pluses. What brand/model saw are you using? Is the bed height adjustable ?
/ roof compleated
Its a "linn 1600"the saw will handle 16" log 20 ft.Fully adjustable , Its sitting on concrete pads.The power head is linn ALL the rest is my scratch built with no plans.Just pictures for reference.
Army Grunt
/ roof compleated #6
Well then, you did a great job building the table. So the head travel (feed) is manual? The table is manual?
We got a Timberking 1600 and adjusting the log to start the square cuts is kind of a bear. Seems like it would be so much easier to stand behind the head and push a button....I ordered some 12vdc scissors jacks to see if that will help.
/ roof compleated
Everything that's yellow I built(from pics,No plans)It has a power feed I built using a 1/2" drill ,an a sears transmission. Using a trigger off a saws all gives me a slow start, then full speed (any of the 3 gears in trans.)All an all its really easy to use.I have a really bad back so I try to make it easy on my self or it would be a no go.
Army Grunt
/ roof compleated
Here are a few more pics of "The build"As said above its scratch built with no plans.Even the electric starter.
Army Grunt
/ roof compleated #9
Sorry, I misunderstood at first. All I can say is, WOW and Kudos. You must have an awful lot of work ahead of you, because you spent the time and effort to get to this point.
Are you guys heli-logging? That's why you need a windsock? :D
/ roof compleated
((((((windsock)))))))I forget its all in a pic.I build an fly r/c airplanes& Choppers:)Also have a Buddie that fly's into my front yard with his J-3 Cub, Thats really cool.
Army Grunt
2023 Case TV450B (A62177)
2023 Case TV450B...
2013 FREIGHTLINER CASCADIA (A63569)
2013 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
HEIN-WERNER TIRE/WHEEL INSTALLER/REMOVER (A63569)
HEIN-WERNER...
John Deere Hood Guard (A63116)
John Deere Hood...
2005 Isuzu NQR 4 door box truck with folding gate (A63118)
2005 Isuzu NQR 4...
