Rollover with Injury.
   / Rollover with Injury. #1
OffBalance
Snohomish, WA (N of Seattle)
2005 New Holland TC24DA
On Saturday, my Grandpa rolled my New Holland TC24. He broke his leg (femur) and is in the hospital for a while.
He was showing me how to use a chain on the loader to lift big rocks. The front wheels of the tractor were on a small mound (12" high or so) in the center of our flat garden area. Then he jumped on the tractor, released the brake, and forget to put it in gear (it is a hydro). He stepped on the forward pedal, but started to go backwards. I saw him continue to try to step on the forward pedal, but not the brake pedal. He rolled about 30 feet backwards across the flat area of the garden, slowing almost to a stop, but reached the edge at the top of a very steep hill.
The tractor went off the edge, and rolled at least one and a half complete times before landing nearly upside down on a log. My Grandpa apparently fell out on the first inversion, but I could only see the bottom of the tractor, so I don't know. I assume he was not wearing his seatbelt.
To give a bit of background, my Grandpa is 94, and has been using tractors constantly since he was 12. He lives alone on 200 acres, and uses his tractors and bulldozers nearly every day, even now. All of his equipment is manual, and this is the first hydro on which he has spent real seat time in his 82 years of operating experience.
Some comments:
Lifting the rock had nothing to do with rolling over - the hill is very steep at the top, and a rollover would have occured even if the bucket was empty and close to the ground. Similarly, I had just installed a tiltmeter, but that was also irrelevant. The garden area has only a 1 to 2% grade. It just happens to be next to a very steep hill.
I have done the same thing (forgetting I was in neutral) a couple of times in a different part of the yard, but always have been able to figure out the problem quickly enough to avoid any trouble.
The tractor has safety interlocks, so that you have to have the brake set and the range select in neutral when you get off the seat, or the engine is killed. Therefore, all of us have gotten in the habit of always putting the tractor in neutral when getting out of the seat, even when turning the engine off. I am not sure if this is good or bad. The tractor doesn't move too much when in low and you are not pressing a hydro pedal. We had a good discussion in the hospital about why the neutral between the H and L ranges is freewheeling. You have to come to a complete stop to shift ranges anyway. I believe a much safer solution would be to have just H-L with no neutral, or Park-Hi-Lo, or some sort of special interlock to get into a freewheeling mode. I have never needed neutral on this tractor, and even on my Grandpa's manual equipment, I only rarely have coasted deliberately in the last 25 years.
Obviously, this could have turned out much worse, and my Grandpa is still very shaken and upset about the situation. He has had a hip joint replaced and knee replaced on that same leg, so he had to have this multiple fracture repaired with a plate on the outside of his femur, screwed to the bone pieces. He has broken a finger or two when operating heavy equipment, but this was the first major limb. Due to his age, this can actually be a very serious injury.
My wife had the presence of mind to grab the camera when the ambulance was there, and captured the dramatic scene I have attached.
I should rephrase that sentence saying I never use neutral on this tractor. I use it all the time - like when operating the chipper-shredder or when hopping off to open a gate. But I never use neutral when moving - I am either in Hi or Lo.
Here is how the tractor came to rest. The old log is holding up the right rear tire.
   / Rollover with Injury. #4
Wow!
That's a heck of a story!
I think your Grand Dad is one heck of a lucky guy! That tractor could easily have crushed him during the roll over. I hope he recovers quickly!
Have you righted your tractor yet? Is it damaged beyond repair?
   / Rollover with Injury. #5
Wish your Granfather all the best and a speedy recovery. Must be some Fellow still out at 94 running equipment.
Egon
   / Rollover with Injury. #6
Yikes!
I hope your grandfather recovers in a speedy fashion.
I hope your doing OK too. Seeing that happen may or may not shake one up for a long time. I hope you all can move forward and put this behind you.
-Mike Z. /forums/images/graemlins/grin.gif
   / Rollover with Injury. #7
OffBalance,
Sorry to hear about your grandfather. Hope he is on the mend and up an about soon.
</font><font color="blue" class="small">( The tractor has safety interlocks )</font>
My little Kubota has an ignition interlock. Must be in nuetral to start. To many times I have release the brakes without selecting a gear range. The BX will start to coast. I have always been able to just press the brake in and stop. But it is disconcerting if only for a breif moment. After 2+ years I still do this occassionally.
Phil
   / Rollover with Injury. #8
You must have been scared out of your wits! Your Grandpa sounds like a pretty tough fellow. I hope he recovers quickly, and fully.
I hope not too much damage was done to the tractor but, machines can be fixed or replaced, Grandpa's are irreplacable!
I too have made the mistake of not being in gear (HST) when releasing the brake. Several times, I have been on a grade when I released the brake and taken off, freewheeling, in a big hurry. Fortunately, I have jammed the brake, rather than trying to put it in gear. Too many times, this has happened when I THOUGHT I had shifted to low before releasing the brake but found I was still in neutral. I have tried to develop the habit of shifting, giving just a bit of fwd or rev (depending on orientation of CUT to any slope I am on) then, after verifying I'm in gear, releasing the brake. I don't know about other HST's but, my 4115 does not always have as positive a feel to the shift as I would like. Sometimes it is a good solid feel as it shifts, other times I'm not sure it really shifted from neutral to gear. This may depend on how hard the brake is set, whether implements are holding it in place, slope..., I'm not really sure /forums/images/graemlins/confused.gif.
After hearing your story and what I have experienced, I'm beginning to think this is a safety issue with HST's. I suppose any manual would do the same if you release the brake while in neutral. I don't know if the shift is more positive or not. In any event, as I said, I now try to always verify being in gear with a touch of fwd or rev before I release the brake and SEATBELT, SEATBELT.....!
Tom
   / Rollover with Injury. #9
Your Grandpa sounds like a cool guy, I'll keep him in my thoughts and prayers.
   / Rollover with Injury. #10
Prayers for your grandfather. And I agree, this is just one more reminder why we need to get on our tractors and the first thing should be "click it".
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
2023 John Deere 6130M MFWD Tractor (A53342)
2023 John Deere...
2012 Seal Rite SR 1000, Tandem Axel Trailer  (A52384)
2012 Seal Rite SR...
1984 Utility 44 ft. Reefer Trailer (A53117)
1984 Utility 44...
BUSH HOG 3308R-2 LOT NUMBER 105 (A53084)
BUSH HOG 3308R-2...
