Rolled my CK20 now it won't start HELP.
   / Rolled my CK20 now it won't start HELP. #11
Fantastic news, very happy all worked out. Good thing when leson learned with no injury to pilot or tractor. Happy diggin.
   / Rolled my CK20 now it won't start HELP. #12
Well done with getting her going!!! But please never under estimate the power of a starter motor, they will bend a rod if the piston hydraulics on a diesel engine. You will most likely get away with a petrol engine as the compressions are much lower but as stated probably wont start until the oil is dispersed. So if it's been on it's side or lid, it pays to rermove the injectors and crank her over.
Once agin, well done.
   / Rolled my CK20 now it won't start HELP. #13
Glad neither you or the tractor was hurt!!!! ROPS can be a pain when it comes to storage height, but they save livesw!!!
   / Rolled my CK20 now it won't start HELP. #14
Just another two cents worth if it's worth that much, but isn't (from what I remember) there a decompression lever on the back side of the engine on the CK20. I'm sure there was on my 2004 CK20. There's no rod or nothing attached to it, but if this were to be held over while cranking, wouldn't it allow any excess oil and fuel to be vented out the exhaust? Maybe some diesel guru's could chime in here and explain this better.
Steve
Hey Steve,
I hope to hear more about that option. My knuckels are still bleedings from putting on those darn fuel lines. :D
   / Rolled my CK20 now it won't start HELP. #16
Yes, there is a compression release lever on the CK20's on the back of the head, right side.
   / Rolled my CK20 now it won't start HELP. #17
To answer the SOP question... if rolled over or somehow suspected of ingesting oil, water, fuel, etc. Start by manually turning engine over with a tool on the crank. If the engine can be turned over twice then go for the start up. Same think you would do when first assembling an engine and checking for valve interference.
LAND OF HONOR HAY GRAPPLE SKID STEER ATTACHMENT (A58214)
LAND OF HONOR HAY...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
Rolling Drain Pan, 44" x 27" w/Pump to Drain (A59076)
Rolling Drain Pan...
2011 MACK CHU (PINNACLE) (A58214)
2011 MACK CHU...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
