Artisan
Veteran Member
Any full time fabricators here?
Gents I need to weld a 1-3/4" x .120 wall tube to a 3" x 3" x .25 wall Square.
The tube sits 7* off perpendicular . It is for a roll bar for a tractor. External
gussets, well, maybe 3 at wierd angles.
I want a very strong connection, not being a "pro" cage builder I am grasping
left and right looking for a good solution.
What if I got a piece of 1.5" OD x .25 wall x .75" tall, DOM, cut it to my angle,
set it on the 3" square and weld INSIDE that, then slip the 1-3/4" that has
an ID of 1.51 OVER the DOM and weld the outside of it to the 3" square?
If OK should I add maybe 4 plug welds as well?
FWIW, the existing 2 U-Bolts you see go away and we will marry this rear
roll bar anchor to the OE ROPS w/ 6-8 1/2" Pro U-Bolts, tall nuts, heavy washers.
