Roll Bar messed up shifting???
   / Roll Bar messed up shifting??? #1
Meerdink1555
Bobcat CT 450
I have a Bobcat CT450 compact utility tractor which is a rebranded Kioti tractor. Recently, while driving at a slow speed the roll bar hit a low hanging (but large) tree branch. The result is a shifting problem. The transmission shift will allow the transmission to engage in all speeds and reverse. However, the forward-reverse-neutral lever will not engage when the transmission is set to the first and third gears but will engage in second and fourth gears. This is a real mystery. Does anyone have any ideas on what the problem may be?
   / Roll Bar messed up shifting??? #2
I’d check the linkages which can be hard to see. My guess is when you hit the limb it jarred something loose.
2018 John Deere 460E Articulated Dump Truck (A53472)
2018 John Deere...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
UNUSED AGT AIR COMPRESSOR W/ 420CC MOTOR (A51248)
UNUSED AGT AIR...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A51247)
2001 WELLS CARGO...
2024 JOHN DEERE 1025R LOT IDENTIFIER 150 (A53084)
2024 JOHN DEERE...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
