rod bearing
   / rod bearing #1
boxorox
jax fl
shibaura s1500/kuboto bx2200/
I know this isnt oficially a tractor but I have a question about my ransoms bobcat front mow. it has a 20 hp onan it broke a rod the only rod I could find is a .030 under new rod for that motor my question is do I order a .030 under rod bearing or a standard bearing or just measure it? also does any body have website that has chart for rod bearings for onan . once again thanks in advance for getting me out of another jam.
   / rod bearing #2
My first thought would be, did it damage/distort the crankshaft.
I'll just assume that model engine used the con rods without inserts.
I found this site that has new & used Onan parts. Onan Parts.Com, Rebuild Parts for Onan engines Lists standard con rods with/without inserts for various models. Probably best to get the model & serial numbers from your engine, and use their search feature to see if they carry parts for your particular model and application.
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
UNUSED AGT SAWMILL MODEL - YC32G (A51248)
UNUSED AGT SAWMILL...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
2005 Ford Taurus SE Sedan (A51694)
2005 Ford Taurus...
LMC LOT IDENTIFIER 130 (A53084)
LMC LOT IDENTIFIER...
