rod bearing
   / rod bearing #1
boxorox
jax fl
shibaura s1500/kuboto bx2200/
I know this isnt oficially a tractor but I have a question about my ransoms bobcat front mow. it has a 20 hp onan it broke a rod the only rod I could find is a .030 under new rod for that motor my question is do I order a .030 under rod bearing or a standard bearing or just measure it? also does any body have website that has chart for rod bearings for onan . once again thanks in advance for getting me out of another jam.
   / rod bearing #2
My first thought would be, did it damage/distort the crankshaft.
I'll just assume that model engine used the con rods without inserts.
I found this site that has new & used Onan parts. Onan Parts.Com, Rebuild Parts for Onan engines Lists standard con rods with/without inserts for various models. Probably best to get the model & serial numbers from your engine, and use their search feature to see if they carry parts for your particular model and application.
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
2006 Husqvarna YTH2148B 48in Riding Mower (A51694)
2006 Husqvarna...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
1992 SYLVAN 20' PONTOON BOAT (A51247)
1992 SYLVAN 20'...
2011 IHI IC-75 Weld Deck Crawler Carrier (A52384)
2011 IHI IC-75...
2009 Pontiac G6 Sedan (A51694)
2009 Pontiac G6...
