Rockshaft not working (Help)
/ Rockshaft not working (Help) #1
tpike35
2004 John Deere 790 w/419 loader and #7 backhoe ..just turn 200 hrs .One week after backhoe was removed 3ph just drop when I was doing some loader work . 3ph was working fine earler that week (scraping the driveway). This tractor is keep out of the weather ... all service has been done by me inclunding 50 hr ...this tractor was bought new in July 2004 ,backhoe w/powerbeyound was added last year I've had the backhoe off twiced makeing sure that lines were clean and cliped together each time ...I changed hyd fuild w/filter and clean the screen (even thought it didn't need it ) ...Loader, power steering and backhoe all work fine .... speed /drop valve is open and no bent hyd lines under or on tractor. I've looked at both bypass valves for trash(system,rockshaft relief)I pulled the rockshaft unit off to look inside for something wrong everything looked fine John Deere dealer was not much help only bring in and we will look at it said that it sounds like the rock shaft valve, about $1000.00 to replaces If that is the case I can order parts to rebuild it myself for under $100.00... any help would be appreated ...
/ Rockshaft not working (Help) #2
I'm not familair with your setup, but think I would start with trying to verify system pressure and flow, and make sure all valves are in their proper position for operating.. and if there are any qd's that are looped ..,make sure they are mated good by removing and reinstalling.. etc
Soundguy
/ Rockshaft not working (Help) #3
This is extreme but have seen many JD's split the actual lift cylinder apart under heavy load . But usually happens under load ( presuming your model has internal cylinder ) sorry thinking out loud
Thanks Soundguy and D7e for your input The tractor has a hose that loops on the power beyound. Which I have inspected and seems to be working fine ... the loader,backhoe and power steering are working right .After alot of inspecting of the overload,rockshaft and main relief valves and hyd lines on the tractor .I pulled the rockshaft housing (thought something might have came loose inside it) everything looked good inside it .... (going by the parts and tec manuals) I did however notice the main spool in the rockshaft valve was not touching the feedbackarm ( not sure if that is right) and the pistion was all the way back also... when I would move the leaver only the feedbach arm would move not touching the spool later on when I went to put it back on( hours later) the feedback arm was touching the spool , pushing it in and out when I would move the control arm , after puting it on and starting up the tractor it sounded like the main spool was pulled right back in so it could not touch the feedback arm I hope this infor will help...
I guess that I'm just going to rebuild the rockshaft valve and replace all seals,o rings and inspecting the seats and springs ,It seemes to me thats all it can be when the loader,powersteering and backhoe all work fine ..They all run off the same pump and system .... I can order the parts for about $20.00 when JD want's $550.00 for the valve...It will be monday before I can order the parts and about 2 weeks getting them so in the meantime if you know something eles that I could have overlooked please let me know tpke35
/ Rockshaft not working (Help) #6
Post back when you drop the parts in and let us know what you found.
Soundguy
/ Rockshaft not working (Help) #7
I had a similar problem on my JD 4210 and it turned out to be the electrical connector under the floor board.
11" QUICK ATTACH EXCAVATOR BUCKET (A60429)
11" QUICK ATTACH...
Ripper Tooth Excavator Attachment (A61567)
Ripper Tooth...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
60in. Work Bench (A65640)
60in. Work Bench...
2016 Ford F550 Crew Cab 4x4 Flatbed Truck (A62613)
2016 Ford F550...
