Rake Rock / Root Rake Question
   / Rock / Root Rake Question #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST, Kubota ZD1021, Kawsaki Mule 4010 trans 4x4
I have have one of these rakes. Some of the tines are bent. Is it ok to heat the bent ones & straighten them ? Or , are they made of some type of special steel & heating them will make them weak or break ?
   / Rock / Root Rake Question #2
Kenmac,
If it is the typical rear rake then the tines are heat treated spring steel and yes heating them will soften them. Although, if they bent instead of breaking, then they may already be softer than they should be.:rolleyes: If you try to cold straighten then they will crack and break. You could try removing them, heating and straightening and then re tempering. Or just buy new replacements. ;)
Mike
thanks mike . It is a typical rear rake. I will check on getting replacments for the bent tines
2025 K2030 UNUSED Metal Garage (A50860)
2025 K2030 UNUSED...
2012 Tiger 130BBL Vacuum Trailer (A50860)
2012 Tiger 130BBL...
2013 GMC Sierra 2500HD 4WD Pickup Truck (A50860)
2013 GMC Sierra...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2018 Peterbilt 348 T/A Pac-Mac Forestry Grapple Truck (A48081)
2018 Peterbilt 348...
2017 Ford Explorer Police SUV (A48082)
2017 Ford Explorer...
