Robotic Following Cart to Replace Light Duty Tractor Tasks?
   / Robotic Following Cart to Replace Light Duty Tractor Tasks?
http://www.mobileye.com/our-technology/
I bet these folks have some coding for you...likely for an indigestible cost
I like the 4wd prototype, keep at it.
I'd like one programmed to go up and down my orchard rows of blooming fruit trees and spray water on them each night in the freezes ahead.
further progress. More to come, just a bit more coding to true smooth following!
   / Robotic Following Cart to Replace Light Duty Tractor Tasks? #132
Browse Papers on Collision avoidance systems : Topic Results - SAE International
not sure you have time to slug through this but I wound up following a link to here, the SAE collision avoidance papers.
Likely a number of distance parameters have to be input and perhaps could be modifiable by the user, like how close to follow
Before you make the final draft of your video, try to get the "actor" to walk as naturally as possible. With an identifiable tool in their hand.
And just because you are in a vineyard doesn't mean it can't be hauling a sack of cement
for a new post somewhere...all purpose, more than one reason to justify purchase. Though for sure the first pic
should be of a cart overflowing with ripe grapes. The bounty, use this cart and look at all these good results.
Male, female and three different nationality users and you should be fine. ;)
Daugen, thank you for that. We'll check that info out!
Here is a customer survey we have set up to get further feedback on our concept. Would appreciate anyone on the forum filling it out if they would be willing as we work towards commercialization.
Also, please check out our website (AGR) from time to time - we are making progress as we work towards commercialization.
Thanks!
Getting close to Smooth Following. This has got to have some uses! Or am I off base?
   / Robotic Following Cart to Replace Light Duty Tractor Tasks? #135
Put that 291 pounds over the caster and try and drive it through soft soil. Workers in the field (or a warehouse), aren't going to take the time to load it evenly or over the drive wheels.
Also, be sure to try it with the weight stacked higher and over one of the corners over the caster. The farther toward the caster and the more toward a corner, the more tippy it'll become.
Then load it that way and drive it across a slope, up and down a slope, and diagonally up and down a slope.
Gotta be sure to figure out load weights, heights, center of gravity. Don't forget, as you turn, even on level ground, your center of gravity will change because the axle of that caster is offset from the centerline of the vertical pivot point of the caster.
Then put that 261 pounds on 2" incrementally higher stands and keep testing.
Lets say someone puts a 55 gallon barrel on there and fills it even half way with water. That's still under 250 pounds. Now take that on the caster end and drive it across a slope and turn while on the slope.
One thing about workers.... they aren't going to obey weight limits. They aren't going to adhere to operating parameters. They're gonna load it with matches and drive it through the dynamite factory. :)
Making progress - getting closer to a cart that can follow you. Now approach we are using allows it to follow you like a dog (remote free -
just walk up, it picks you up, and starts following you). Short clip of it here: Instagram
   / Robotic Following Cart to Replace Light Duty Tractor Tasks? #137
that was pretty neat. I could not help but wonder if you made this thing into a lifelike dog companion,
it would sell just for the doggy part, as an expensive Hammacher Schlemmer toy, not a tool.
However, back to grapes...
Remember, fill it up with grapes for a promo shot! Look, the bounty follows you home...
Just about every major company in my area is looking for employees, and the common lament is you can't get good help.
Part of that now is due to drug testing, but the reality is we are at low unemployment. So if folks can't get enough good help, and want
reliable help anyway...now might be a good time to market this as a long term investment in controlling staff costs and improving reliability.
I see help wanted signs out at the end of your marketing lane, with the owner/grower looking interested at this new idea...
I also see this device in a greenhouse setting loaded with cut lettuce heading down the aisle.
If this doesn't have a remote, perhaps some audible software for at least a stop command if the radar glitches and doesn't
fail in the stop mode as it's supposed to. And it can't wake up in the middle of the night and go for
a ride in the barnyard. :D
could there be a level switch where it will stop operation if the angle exceeds X?
I made a home made water wagon with a 55 gallon drum like MossRoad talked about and when it's full, even on a good quality JD cart,
you can feel the whole thing wanting to lean if I get close to a ditch. Otherwise I live on very flat land and the water wagon works great.
And a water wagon which followed you as you watered things not under irrigation might be a neat application.
There's always the issue of how much do you have to overdesign something to make up for improper/unsafe operation. And if it does get stuck, or turn over, or
suffer some upset, being all electric, and likely agm or lithium batteries, it should be exceptionally durable.
You can put a lot of safety nannies on a cart like this, a weight sensor under the bottom that stops operation if payload weight exceeds X.
Daugen,
Thanks for the thoughts and tips! We think we can fix a lot of the unsafe stuff and mechanical shortcomings - the key is getting the robotic part to work and at a price that actually creates value for people...
Here, finally, is a good video of our idea and team. Welcome any feedback (the good, and the bad especially!).
Thanks!
   / Robotic Following Cart to Replace Light Duty Tractor Tasks? #139
Excellent!
Excellent!
We are now working on fundraising, and running pilots with people picking a lot of crops or in other applications where they people are wasting time doing work, then moving around 50-150 pounds of what they have worked on, from place to place. With our concept, you can just send the cart back to a collection point as you keep working.
Also, you mentioned the point about tipping over. We have an IMU sensor which measures roll/yaw/pitch and can do this (shut down/stop if the slope becomes too great).
Can anyone imagine uses? Thus far we are planning to focus first on hand picked fruits (permanent rows, narrowest vineyard tractors like the Deere 5075GV) go down to about 43 inches, so anything beneath about 50 inch row spacing can't really be machine shuttled off the field, rising labor rates, a lot of time wasted running stuff back and forth. Looking for feedback/advice on the pros/cons of this or other areas we should think about.
Thanks!
8 Piece Mini Excavator Heavy Duty Attachment Set (New/Unused) (A59225)
8 Piece Mini...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
2021 Fleco DX140 24in Digging Tooth Bucket Excavator Attachment (A55973)
2021 Fleco DX140...
Mini Skid-Steer Stump Grinder (New/Unused) (A59225)
Mini Skid-Steer...
2012 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2012 MACK CHU613...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
