Robin Engine Charging Capacity
   / Robin Engine Charging Capacity #1
pairodime
Bronze Member
VA
PT-425
The manual for my EH72 engine says the charging capacity is either 15 amps or 30 amps. Anyone know how to tell the difference without taking it apart? Jack, are you out there?
   / Robin Engine Charging Capacity #2
My 22 hp Robin came with a 30 amp voltage regulator which didn't last very long and was replaced under warranty. The replacement didn't last either. I worked with Jack thinking it might be the charging coils. The output of the charging coils should be 36~40V AC at 3600rpm.
The 30 amp voltage regulator is over one hundred dollars the 15 amp voltage regulator is about $20. I bought the 15 amp regulator and have been using it with out problem.
The 30 amp regulator is about twice the size of the 15 amp regulator. The part number of the 15 amp is 263-71901-01. The part number of the 30 amp is 263-719-02-A1
Hope this helps, /forums/images/graemlins/smile.gif
Dale
   / Robin Engine Charging Capacity #3
</font><font color="blue" class="small">( My 22 hp Robin came with a 30 amp voltage regulator which didn't last very long and was replaced under warranty. The replacement didn't last either. I worked with Jack thinking it might be the charging coils. The output of the charging coils should be 36~40V AC at 3600rpm.
Dale
)</font>
You're the man! You could work in my Dept! /forums/images/graemlins/grin.gif /forums/images/graemlins/wink.gif
A little correction though, the AC output from the charge coil should be anywhere from 36-60V AC.
Jack
   / Robin Engine Charging Capacity #4
</font><font color="blue" class="small">( The manual for my EH72 engine says the charging capacity is either 15 amps or 30 amps. Anyone know how to tell the difference without taking it apart? Jack, are you out there? )</font>
Most likely, this engine has a standard 15amp charging system. What is the engine spec?
Jack Gawecki
Jack,
The plate on the engine has the following number- e13*97/68SN4G2*2002/88*0019*00
There is also an engine family listed of 4FJXS.7202GA
and finally a product number of EH720DS00116306
Hope this helps.
   / Robin Engine Charging Capacity #6
This engine is equiped with 15amp charging system.
Regards,
Jack Gawecki
Robin America, Inc.
Technical Support Dept.
UNUSED HURRICANE 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
FREIGHTLINER BUCKET TRUCK (A51406)
FREIGHTLINER...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
UNUSED FUTURE 1R RIPPER (A51248)
UNUSED FUTURE 1R...
