Robin Engine 500 Hour Maintenance
/ Robin Engine 500 Hour Maintenance #31
<font color="red"> Just go and add a Nitrous Oxide kit with a big red button! </font>
Thus eliminating the need for 500 hour maintenance the first time the button is pushed. Brilliant!! /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
Today I made the valve clearance adjustment recommend at 500 hours on my PT422 Robin-Subaru engine. The hardest part was rotating the shaft to the proper position. I could not see the timing mark on the flywheel, so I turned the shaft with a large pair of slip joint pliers until the compression was at a max and the cylinder head that I was working on had the valves fully closed. The recommend gap was 0.085 to 0.115 (nominal 0.1) mm. I did end up make adjustments in all of the valves. I do not see a difference in the way the engine runs, but it is good to have this done. I replaced the rocker arm cover gaskets, especially since one was leaking and damaged a little bit, probably from a previous removal to create clearance while changing the starter motor.
Overall not a partically difficult task.
Bob Rip
2023 John Deere 325G (A60462)
2023 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A61166)
IMPORTANT PLEASE...
2018 Enclosed Trailer (A60352)
2018 Enclosed...
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
