Robalon skid shoes for 59" front mount blower
   / Robalon skid shoes for 59" front mount blower #1
Mechanos
Roosterville, MO
JD 955/70A/7 TLB
The recent storm we had here in the mid-west gave me an opportunity to try out the new Robalon skid shoes I bought for my 59" blower. These shoes bolt to the sides of the blower frame directly beneath the centerline of the auger. The two steel skids bolted to the back of the blower frame are retained. The Robalon shoes performed very well, but there is one little quirk. With the shoes mounted in there lowest position, they hold the scraper edge about 3/4" off the ground. While this works quite well for my my gravel area and on the grass, it leaves behind more snow than I care for on the pavement. I may have to slit a piece of pipe a slide that over the edge to extend scraper closer to the ground.
   / Robalon skid shoes for 59" front mount blower #2
Which shoes did you order? I also have a 59" blower on my 855 and am looking into replacement shoe options. thanks.
   / Robalon skid shoes for 59" front mount blower #3
Do you have any pictures of the install? Thanks
2025 IR UNUSED Hydraulic Thumb (A53117)
2025 IR UNUSED...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A53473)
3-Point Hitch Root...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
