Road thru woods
   / Road thru woods #11
I've done similar and found it rewarding... one rule is stop for the day when you feel fatigued if working on a slope... doesn't take much to find yourself in an awkward situation.
I did use my backhoe a lot to get a lever spot to work from.... over the years I made it wider.
Later I started using a Dozer and the 6 way blade starting from the top and blazing down sure made quick work...
If you don't get too carried away... nature will show you what needs attention... I use dips with some strategically placed fallen trees to control water...
Spent about 4 hours on Sunday at the ranch blading the trails with my brother's JD350 dozer...
2010 Ford Transit Connect Cargo Van (A55788)
2010 Ford Transit...
2023 Club Car Carryall 700 Utility Cart (A54811)
2023 Club Car...
PAIR OF UNUSED 60" HANG ON FORKS (A54757)
PAIR OF UNUSED 60"...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A56129)
2022 MACK GRANITE...
INSPECTION (A54865)
INSPECTION (A54865)
2025 JMR 40in Single Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 40in...
