RK37 dash lights
/ RK37 dash lights #1
RK Farming
Rual King 37
I have a new RK37 and it's not wired to illuminate the parking brake lamp or 4x4 light on the dash. Does any have a RK55 wiring diagram? I want to add the necessary switches to make those dash lights work.
Thanks in advance.
/ RK37 dash lights #2
That seems pretty strange . . . . You need to flip a switch in order to have these lights come on?
Seems only common sense that those "warning / info" lights would illuminate when the parking brake is engaged and when the 4x4 is engaged. Having those circuits run through an auxiliary switch defeats the purpose.
Are you sure that there isn't a fuse blown? Have you been able to check another R37?
/ RK37 dash lights
I contacted the manufacturer, they said the display or dash is used on multiple models and the RK37 does not use the parking brake or 4x4 warning lights.
So, I'm thinking that since the RK55 does have these functions I could study the wiring diagram and figure out what switches I need and where to install them.
/ RK37 dash lights #4
OH. Duh. I get it now. LOL. Good luck with it. If you come up with a modification that works, you could probably market it to other RK37 owners.
/ RK37 dash lights
If I get it figured out I will definitely the results here. Thanks
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
2014 Ford Explorer (A62613)
2014 Ford Explorer...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
2012 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
