RK37 Check Engine lamp, How to clear
   / RK37 Check Engine lamp, How to clear #1
USEngr
Rural King RK37 SS
New member here, I have a 2019 RK37 Shuttle Shift. It has about 155 hrs and up till now, has run great. The other day, the check engine indicator (Crankcase outline with an "!"inside) came on. Shortly after that the symbol for a regen came on.. No biggie, I've always just moved over to a safe location and initiated a regen and let it do it's thing. This time, as I stopped what I was doing (Moving a water tank from tree to tree filling up watering bags) and as I was moving over to a good spot, the Regen (ACK) button went back out but the Check Engine lamp stayed on. I've tried several times to initiate a regen, but nothing seems to work. I've stopped using the RK37 for now pending a resolution. I've got calls in both at my local RK store and RK Corporate service. So far no response from either. Anybody have any idea what's going on & either some way to manually force a regen or a manual way to clear the Check Engine Lamp? (That's assuming the check engine lamp being stuck on is related to the Regen light coming on & going off..)
PS I've searched these forum posts and didn't see anything similar to what I am experiencing..
   / RK37 Check Engine lamp, How to clear #2
On my 37 HST, the light stayed on when my return fuel got crimped off, it runs along the frame and left rear fender and can get pinched . Check your fuel system.
   / RK37 Check Engine lamp, How to clear #3
According to my local RK guy, only their mobile tech carries the ODB reader and is the only way to reset the light. I disconnected the battery after my repair and it stayed off.
   / RK37 Check Engine lamp, How to clear #4
I got this and the tractor stalled when I ran out of diesel. Hot day going up hill. Would not turn over but I think I forgot to press the brake pedal. Added 5 gallons the next day, battery at 12.5 volts. Turned over and I had to crank it a few times before the engine caught.
2016 CATERPILLAR 306E EXCAVATOR (A51246)
2016 CATERPILLAR...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2006 HAMM 3205 SMOOTH DRUM ROLLER (A51246)
2006 HAMM 3205...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
UNUSED FUTURE FT-P45 HYD BREAKER HAMMER (A51248)
UNUSED FUTURE...
