RK24 info
   / RK24 info #1
Alverian
MF 35
I am looking at getting a RK24 and was wondering what the inside width of the bucket and the thickness of the cutter edge was. I am also looking at a add on for it and need this info to see if it would fit before I buy.
   / RK24 info #2
I just took delivery of my RK24 yesterday. I can get you these measurements tonight after I get home from the movies. Probably 11pm or so.
   / RK24 info
Cool thanks, been trying to get info for a while tried RK and got check the online info. Well not there.
   / RK24 info #4
Do you have an RK store near by that you could stop and look at one easily? If the measurements are important in the purchase decision, you may want to make sure that the measures are done in the manner that you'd like them measured. No offense intended for anyone...but having confidence in the measure (as a buying criteria) seems like it would be important in this case.
   / RK24 info #5
I'm a draftsman by trade so I'll get you some accurate dims. Don't worry.
   / RK24 info
I have 2 stores but both are like 3-4 hours away.
   / RK24 info #7
Here are the cutting edge and bucket dims you wanted, as measured from my RK24 with 50" bucket.
The first picture is a cross section view of the cutting edge with the leading edge to the right.
The second picture is a top view of the cutting edge and bucket walls. The cutting edge is a little wider than the bucket walls and has small (maybe .125") fillet welds on both sides of each wall.
There are also two fillet welds shown in the cross section view.
   / RK24 info #8
Nice drawing! I was a draftsman way back in the day and appreciate attention to detail. I'm sure it will be helpful. Website, shop manuals, owner's manuals, just don't have that kind of information. And you know what? Sometimes you just need to know. :)
   / RK24 info #9
That was just a quick 5min AutoCAD sketch, but thanks.
   / RK24 info #10
Yeah, my drafting days were pre-AutoCad. T-square, triangle and mechanical pencil.
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2022 CATERPILLAR 306CR EXCAVATOR (A51242)
2022 CATERPILLAR...
2010 MACK MRU613 GARBAGE TRUCK (A51243)
2010 MACK MRU613...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
Case 721B (A47384)
Case 721B (A47384)
