RK24 Hydraulic failure
   / RK24 Hydraulic failure #1
Fergenheimer
RK24, Satoh Buck, Deere 5103
Just joined the community. This post is to both ask and provide information.
I have a problem with my RK24 Hydraulic divider block. There is plug on the bottom side of it which blows out the o-ring seal. This happened to me and since I am out of warranty, I replaced the o-ring and it was "fixed". I had hoped that this was a one-off occurrence. Then it happened again.
Second time, I notice the hydraulic pump changed tone when in a hard right turn. I have not changed the o-ring again. I will but wondering if anybody else has had this problem. I doubt that my problems are unique and if you have seen this I would appreciate hearing about it.
Thanks
   / RK24 Hydraulic failure #2
I suggest posting this in the hydraulics forum for a wider range of eyeballs on the question.
It sounds like excess pressure. You may have a relief valve stuck. You can buy, make or get a shop to use a pressure test gage to verify the spike in pressure.
Could be the result of a collapsed or damaged line or possibly damage to the ps cylinder itself.
The closest relief valve appears to be under the cap nut to the right on the valve body pictured.
If you're out of warranty, TYM built that tractor so their dealer is likely better positioned to help than rk.
Thank You @agjones. Over pressure is what I suspect also. The hydraulic diagram does not show a relief valve. I was going to look at the hydraulic pump for a relief valve next. I will look under the cap first then. I was going to order a gauge and tee to tie it into the pump discharge line. Any idea what pressure should be?
Thanks again for the help.
   / RK24 Hydraulic failure #4
Relief valve should be in the first component connected to pressure port of the pump. Do you have a schematic showing what that component is that the seal is failing on?
@oldnslo , it is a divider block. I cannot find a schematic of the internals but the attached are from the parts manual. If I read the schematics right, the steering column drains back to the sump through its own hose. The loader drains back through this divider block.
This time that it failed, I noted a change in sound when I was in a hard right turn. This might be coincidental. First time I saw the leak, I have no idea how long it was leaking. Two other things that are probably coincidental, this occurred shortly after my 50 hour maintenance at the dealer and my wife saw the bucket was holding water and breeding mosquitos. She started the tractor and operated the controls to tilt the bucket. Whether you run the steering cylinder or the bucket cylinders to the end of travel and still hold it, all the oil should return and not build up pressure.
  • RK24 Hydraulic Sub.pdf
  • RK24 Loader Hydraulics.pdf
  • RK24 Steering Valve.pdf
   / RK24 Hydraulic failure #6
Is there only one pump on this tractor? By the attachment I would say yes and that block is used to house a priority flow control to provide flow to steering and excess oil to the FEL circuit. Turning to stop will cause pressure to build to relief setting and yes you would hear this same as operating FEL function to end of stroke. The higher pressure would increase chance of seal failure but should not be the root cause.
did you or the dealer ever check to see if pressure settings are to spec?
Was that plug lose when the seal blew?
I have not taken it to the dealer for any troubleshooting. I did show them the pictures above and a video of the block spraying when I operated the loader. They said they had never seen anything like that before. Also did not offer up any additional drawings on that block. The block through RK was $421.58.
I do not recall if the plug was loose. It is on the bottom of the block and mounts on a plate so it cannot back out. When I replaced the o-ring, I did not over torque it since extruding an o-ring is easy to do. Internal to the block beneath this plug, was a ball and spring. Hard to get a good picture. Thought that this might actually be an emergency relief and it is supposed to blow out instead of rupturing something else.
   / RK24 Hydraulic failure #8
There are often multiple reliefs in the system. Under that nut is either a relief or an adjustment for the divider.
I think you're on the right track. That lil plug w oring could be a bleeder. It's possible that air was introduced to the system during filter change and pushed out at the oring.
400 is plenty of $for the block but not extreme. Money or time...
The factory cylinders are 2500 and 3000 psi. Typically tractor pressure is around 2300.
Thanks for the info. I just traced out the lines. The return and supply line skirt up under the body and seat area so it is tough to be sure but it looks like the return line is routed to an aux valve on the right column of the ROPS. From there it would return to the sump. Since I generally crawl up on the tractor that way, if I hit the valve and it is not in the neutral position, could that obstruct the return and jack up pressure?
   / RK24 Hydraulic failure #10
hard to tell what function is on that valve or plug you removed. I do see a small hole between the O-ring and threads so suspect some form of pilot signal or possibly pilot for relief valve. Again this is just a guess.
I presume there was a lead in chamfer for that O-ring and be careful on the torque during installation.
Possibly silly question but how did you size the replacement O-ring. These frequently are not standard hardware store sizes and one to large would cause problems on installation and potentially blow out much easier. Probably a metric seal
2015 Ford F-350 Knapheide Service Truck (A55852)
2015 Ford F-350...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A54811)
Generac Yanmar...
2016 Sakai SV540 Padfoot Compact Roller (A54865)
2016 Sakai SV540...
2020 FREIGHTLINER M2 106 BOX TRUCK (A56129)
2020 FREIGHTLINER...
2015 Ford E-350 Cutaway Van (A55973)
2015 Ford E-350...
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
