RK19 / RK24 First 50 hour service, DIY.
   / RK19 / RK24 First 50 hour service, DIY. #1
BoneStock
Bronze Member
Kentucky
RK19, 79 IH 682, 98 Murray Widebody LT
   / RK19 / RK24 First 50 hour service, DIY. #2
Great info Bonestock...I'm planning on doing my RK24 this weekend.
   / RK19 / RK24 First 50 hour service, DIY. #3
Started my 50 hour service this morning on my RK 24, all went well until the trans/Hyde change out. The filter is almost impossible to get to for change out, so I suggest routing another hydraulic line or brace across it to make it impossible 😂. I have 3 drain plugs. One on each final and one in the middle. So this brings me to my issue. Should I drain through all 3 or just the bottom plug?
   / RK19 / RK24 First 50 hour service, DIY. #4
Just curious how does that screen filter come out?
   / RK19 / RK24 First 50 hour service, DIY. #5
Oh yeah I forgot to add that as well. I do not see where it is located. Bonestock's seems to be right at the throw away filter.
   / RK19 / RK24 First 50 hour service, DIY. #6
I went to the local Rural king and ordered the filters for my service. Thought I would show the process, although straight forward, just some advice and steps I took. Performing hydraulic services is a major service at my job, and was surprised how much metal was on my pre pump screen on my tractor.
RK19 RK24 MAINTENANCE. 5 HOUR SERVICE. DIY!! HOW TO? OIL CHANGE, FILTER CHANGE. RURAL KING TRACTOR - YouTube
Awesome video Bonestock. Concise and well produced. Will definitely help others who choose to perform their own service. Great job!
   / RK19 / RK24 First 50 hour service, DIY. #7
On my RK24, I removed the rubber hydraulic line at the fitting beside the hydro. filter to gain access. Gave me enough room to get the filter out of captivity! I never found the screen filter shown on the RK19 video. Still looking though!
   / RK19 / RK24 First 50 hour service, DIY. #8
Where did you drain the hydro? Through the bottom plug on the side of something that looks like an appendage dachshund would drag through the snow?
   / RK19 / RK24 First 50 hour service, DIY. #9
Yep, right inside of the dachshund's left rear leg! Can't miss it.
   / RK19 / RK24 First 50 hour service, DIY. #10
After seeing the tracks in his first snow I understood why the little fellow hates it! Ha!
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A51039)
NEW 2022 Load...
Hay Fork (A50860)
Hay Fork (A50860)
2016 Big Tex 12ft. S/A Utility Trailer (A48082)
2016 Big Tex 12ft...
2013 Honda Odyssey EX-L Mini Van (A50860)
2013 Honda Odyssey...
2002 Ford E-250 Cargo Van (A48081)
2002 Ford E-250...
