RK19 / RK24 First 50 hour service, DIY.
   / RK19 / RK24 First 50 hour service, DIY. #1
BoneStock
Kentucky
RK19, 79 IH 682, 98 Murray Widebody LT
   / RK19 / RK24 First 50 hour service, DIY. #2
Great info Bonestock...I'm planning on doing my RK24 this weekend.
   / RK19 / RK24 First 50 hour service, DIY. #3
Started my 50 hour service this morning on my RK 24, all went well until the trans/Hyde change out. The filter is almost impossible to get to for change out, so I suggest routing another hydraulic line or brace across it to make it impossible 😂. I have 3 drain plugs. One on each final and one in the middle. So this brings me to my issue. Should I drain through all 3 or just the bottom plug?
   / RK19 / RK24 First 50 hour service, DIY. #4
Just curious how does that screen filter come out?
   / RK19 / RK24 First 50 hour service, DIY. #5
Oh yeah I forgot to add that as well. I do not see where it is located. Bonestock's seems to be right at the throw away filter.
   / RK19 / RK24 First 50 hour service, DIY. #6
I went to the local Rural king and ordered the filters for my service. Thought I would show the process, although straight forward, just some advice and steps I took. Performing hydraulic services is a major service at my job, and was surprised how much metal was on my pre pump screen on my tractor.
RK19 RK24 MAINTENANCE. 5 HOUR SERVICE. DIY!! HOW TO? OIL CHANGE, FILTER CHANGE. RURAL KING TRACTOR - YouTube
Awesome video Bonestock. Concise and well produced. Will definitely help others who choose to perform their own service. Great job!
   / RK19 / RK24 First 50 hour service, DIY. #7
On my RK24, I removed the rubber hydraulic line at the fitting beside the hydro. filter to gain access. Gave me enough room to get the filter out of captivity! I never found the screen filter shown on the RK19 video. Still looking though!
   / RK19 / RK24 First 50 hour service, DIY. #8
Where did you drain the hydro? Through the bottom plug on the side of something that looks like an appendage dachshund would drag through the snow?
   / RK19 / RK24 First 50 hour service, DIY. #9
Yep, right inside of the dachshund's left rear leg! Can't miss it.
   / RK19 / RK24 First 50 hour service, DIY. #10
After seeing the tracks in his first snow I understood why the little fellow hates it! Ha!
1994 Case 721B Wheel Loader (A55272)
1994 Case 721B...
LOT: (6) Ratcheting Chain Binders (A59076)
LOT: (6)...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57453)
New/Unused 20ft...
S/A TRAILER (A58374)
1990 LOAD KING BELLY DUMP (A58214)
1990 LOAD KING...
DEL MORINO VICTOR FLAIL MULTCHING MOWER (A58216)
DEL MORINO VICTOR...
