RK 55 HST Cab regen symbol
   / RK 55 HST Cab regen symbol #11
Good stuff. Thanks for posting Gunny.
Got the tractor back today. Apparently a Florida rodent variety ate a wire leading to the sensor. The great news is that the bucket/FEL has been leveled. Shawn, took the time when he dropped the tractor back off to me to explain the process with the loader, how he leveled it and how it’s possible that they aren’t completely level. Whatever the cause, it is less than an 1/8” of gap, where before it was over 1 3/4” of gap on one side.
This began as a boggling issue and ended up being quite pleasant and refreshing.
   / RK 55 HST Cab regen symbol #13
Glad to hear it!
   / RK 55 HST Cab regen symbol #14
That’s great news!
   / RK 55 HST Cab regen symbol #15
Very nice !!!
   / RK 55 HST Cab regen symbol #16
Fantastic news!!!
   / RK 55 HST Cab regen symbol #17
Wow, that is great to hear. Glad they were able.to resolve it.
   / RK 55 HST Cab regen symbol #18
Got the tractor back today. Apparently a Florida rodent variety ate a wire leading to the sensor. The great news is that the bucket/FEL has been leveled. Shawn, took the time when he dropped the tractor back off to me to explain the process with the loader, how he leveled it and how it痴 possible that they aren稚 completely level. Whatever the cause, it is less than an 1/8 of gap, where before it was over 1 3/4 of gap on one side.
Gunny - do you mind passing on the leveling info?
So from what Shawn told me (granted this was done in the Williston facility) he unbolted the FEL after placing it on blocks and then once it was leveled he had himself and another person tighten the bolts down. Apparently what happens is that one person usually installs the loader. And you have to go side to side to tighten the bolts. If it is uneven at all, the person tightening the bolts probably won’t notice. I was told that if it’s off a 1/8” at the bolt hole it could be off more at the loader itself.
I don’t know how much of this makes sense or if it’s accurate. I will say that mine is more level now than before he took it. It has barely an 1/8” of gap.
So who know, this is what I was told. But as for what was actually done, I wasn’t there.
   / RK 55 HST Cab regen symbol #20
That story does kinda make sense.
6' SCRAPE BLADE (A52708)
6' SCRAPE BLADE...
Case-IH 370 Steiger (A57148)
Case-IH 370...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
2018 KENWORTH T800 HOTOILER (A58214)
2018 KENWORTH T800...
BUNDLE OF 4" - 6" X 12' BUILDING PURLIN (A54757)
BUNDLE OF 4" - 6"...
2023 yamaha (A55758)
