RK 24 3 point rating
   / RK 24 3 point rating #1
4tillingdirt
nc
N/A
Isn't the RK 24 considered a limited category 1? I know the RK site lists it as Category I 3-pt. hitch but I think that may be a misleading when comparing it to other tractors that size.
   / RK 24 3 point rating #2
Is there actually a definition (with numbers) for limited cat 1 like there is for cats 0, 1, 2, 3 etc? I've read that what makes a cat 1 "limited" is the lack of lift height due to the shorter nature of some SCUTs. The RK24, however, has larger tires than most other SCUTs of similar size, so this may negate the issue. Maybe someone who has more knowledge can offer a better understanding here?
   / RK 24 3 point rating #3
I can't help with terms like "limited cat 1". I can tell you a Japanese cat 0 rating has much in common with the American cat1, such as pin diameter. The spacing between arms though is the same as the American cat 0. I don't know that there is a firm definition for "limited" cat I. Three-point hitch - Wikipedia
2014 Ford Explorer AWD SUV (A53424)
2014 Ford Explorer...
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A53421)
Caterpillar...
2020 Toro Pro Sweep Vacuum (A55787)
2020 Toro Pro...
Ammco Brake Machine (A55758)
Ammco Brake...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55314)
PENDING SELLER...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A55745)
2015 VANTAGE...
