RIVERLIVER FINALLY GOT A NEW X500
   / RIVERLIVER FINALLY GOT A NEW X500 #1
RIVERLIVER
COLOMA, CALIF
JD 410C BACKHOE
I FINALLY TOOK DELIVERY ON MAY 10TH AND I LOVE IT. HOWEVER BEFORE I HAD .5 HRS ON IT I RAN OVER A NAIL IN THE GRASS AND FLATTENED MY RIGHT FRONT TIRE. WENT DOWN TODAY AND HAD A TUBE PUT IN IT. I COULDNT BELIEVE THE TIRE PRESURE THAT JOHN DEERE HAD IN THE TIRES. THE FRONTS WERE BOTH 25PSI AND THE REARS WERE BOTH 30PSI, WHATS UP WITH THAT?
   / RIVERLIVER FINALLY GOT A NEW X500 #2
Welcome to TBN. :)
THANK YOU FOR YOUR FRIENDLYNESS.
   / RIVERLIVER FINALLY GOT A NEW X500 #6
Hello RIVERLIVER welcome to TBN. I bought a new X500 on April 27. Agree with you that X500 is an awesome mower! :thumbsup: Thanks for the heads-up on the tire pressure. Owner's manual says front 14 PSI, rear 10 PSI. Checked mine and they were in the ballpark, front 16 PSI, rear 9 PSI. Wonder if yours were inflated at factory and dealer didn't check them?
Also don't forget to change your oil and filter at 8 hours. My dealer said that's important.
   / RIVERLIVER FINALLY GOT A NEW X500 #7
Welcome
   / RIVERLIVER FINALLY GOT A NEW X500 #8
Welcome from NY!
   / RIVERLIVER FINALLY GOT A NEW X500 #9
Welcome. X500 is a wonderful machine. You are not alone on the tire pressure. I took my tires in to JD dealership a few months after i bought it to be loaded with rim guard. The too came back at around 30psi. I made a mess out of my garage floor letting pressure out. Looked a bit like a CSI crime scene.
Enjoy your tractor!
MAGNUM PRODUCTS 35KW GENERATOR (A50854)
MAGNUM PRODUCTS...
2008 Kenworth T300 T/A Knuckleboom Crane Truck (A50323)
2008 Kenworth T300...
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump with Hose Reel (A49461)
2025 LandHonor...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2013 Doyle Dry...
Quick Attach Stump Grinder (A50514)
Quick Attach Stump...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
