ripping before Tilling
/ ripping before Tilling #1
troweller
Bronze Member
Kubota 3010, Farmall Cub
Is necessary to rip behind the tire tracks before tilling to achieve maximum depth?
/ ripping before Tilling #2
Unless you have hard-pan or clay the tiller should be fine on its own. You could make the first pass a little shallower than the second.
/ ripping before Tilling #3
I'm putting more area into garden this yr and the soil is pretty hard...and rocky. Im planning to rip prior to tilling.
/ ripping before Tilling #4
I don't think it is necessary at all, your tiller should be able to handle the sod or whatever you have without any preparation work.
I did use the scarifiers on my box blade to rip up the sod on a couple of new garden plots this spring, but that was just to help the soil dry out a bit faster so that I could play with my new tiller!
/ ripping before Tilling #5
I have been doing some tilling this past week and weekendanaged one row before the rain hit /forums/images/graemlins/mad.gif I box bladed with full down scargfers in the garden for 2 reasons. one to rip out old vines and to break up the old hard wet ground some for drying. I also have been ripping virgine soil for the last couple days. to DRY and to pull out the longer vines and hard weed stalks. I don't have a routary YET if I did I would have run that first to help dry it out by getting the cover off. I DID scare up a nest or two of baby gardner snakes... hopefully I didn't crush too many if any of them... The buggs will get too far out of hand if I did!
also I took some creek bed photos and will try to post them tomarrow.
Mark M
/ ripping before Tilling #6
Last night I borrowed a box blade and ran it thru most of the area (it got dark on me) Im planning to open. I pulled out quite a few rocks and there are still some more that need to be gotten out. I found that cross hatching the area did the most complete job. So, the pile I pulled out won't be cycling thru my tiller.
/ ripping before Tilling #7
"...to pull out the longer vines and hard weed stalks..."
That's a good point, and one I had forgotten about. By running my BB over the ground with scarifiers down, the BB tilted as far forward as possible, and the blades just skimming over the ground, I was able to clear off most of the dry plant matter.
As far as the remaining grass and roots, it looks as if the tiller completely "vaporized" them! /forums/images/graemlins/laugh.gif
/ ripping before Tilling #8
As others have said it will not hurt to rip before tilling. If you pull up a bunch of rocks then you will have another job before tilling.
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
FERGUSON PEANUT RE SHAKER, 3PT (A62130)
FERGUSON PEANUT RE...
PAIR OF DIAMOND PLATE DBL AXLE FENDERS (A62130)
PAIR OF DIAMOND...
(2) 30 Yard Dumpsters (A61166)
(2) 30 Yard...
2018 CATERPILLAR 906M WHEEL LOADER (A62129)
2018 CATERPILLAR...
