Ring and pinion gear
   / Ring and pinion gear #1
simon10
Diksmuide, Oost-Vlaanderen
Yanmar F16D
Hello,
I've got quite a problem with my Yanmar minitractor, lately I lacked traction when using the plough. I thought it was the clutch, however when examining the rear axle, I saw that the ring and pinion gear are seriously worn. I have been contacting dealers in Belgium and Holland (where i'm from), however the major problem is that it is a F16D and this is a grey market tractor in Europe. Do you guys have an idea if there are any compatible tractor models that have the same ring and pinion gear? Maybe the F165 (which has similar power and is from the same time range? +- 1983-1986).
Thanks in advance!
Simon
   / Ring and pinion gear #2
You need to get a parts dealer to give you the correct part number. Searching by part number will combine any models that share that number. I know the F20 through F24 share the same ring and pinion and it is available but I doubt it is the same as the F16. Here is an old post indicating you might have to find a used one. http://www.tractorbynet.com/forums/yanmar/136642-yanmar-f16d-ring-pinion.html
Does seriously worn mean teeth missing. By loosing traction either bolts are sheared or teeth missing?
In Belgium, there are no parts dealers, sadly. I have been searching for the part number but cannot find it.
Yes, some teeth are missing (only the bottom part of the teeth are still there).
The only thing I have at this moment is the dimensions of both gears.
   / Ring and pinion gear #4
I feel like these folks might share the part number with you and might give you good information about availability on the gears. Yanmar Tractor Parts:
   / Ring and pinion gear #5
Isnt that the tractor or tractor series that there are no gears to be had? I think you need to find a doner tractor. One may have to be sourced from asia so you may need a person who knows how to procure that sort of thing.
I would try Hoye first of course, they are experts. Also maybe fredericks in alabama. Shipping would be killer from the US but at least if its here you could have it!!!
   / Ring and pinion gear #6
I can't really help other than to post a couple of links European parts sellers I've come across. Maybe if you email them they could offer some advice? Hope you get it sorted out.
Yenibiz
Tracpartz
   / Ring and pinion gear #8
I also have a Yanmar F16D with a bad ring and pinion gear. What a education looking for those parts. I even found one salvage yard that wanted $1,275.00 used . yes I did tell them where to go. NOW for the good news .Southern Global tractor 601-928-7491 can order the ring and pinion gear from Japan shipped for $ 850.00 to your door . it takes two to three weeks. OEM parts # 194193-31390 ---- $800.00 plus $50 shipping.
I E-Mailed and called many tractor places that deal with gray market tractors in the USA and Canada and only Global responded yes.
it is well worth it to repair the tractor being a 4X4 for that price
PLUS=== Hoye tractor parts has the parts manual reduced for $ 39.99 [copy] that will help 940-592-0181
PS request to have the manual shipped in a envelope. costs about $ 6.50 compared to $12.95. it may get to you bent shipping it in a envelope.but a big savings
I even searched in Canada. it goes to show never give up. all it takes is one company to respond
   / Ring and pinion gear #9
I also praise Southern Global.
Dealt with Anna Eckers.
Needed ring and pinion for my Mitsubishi some years back and Southern Global came thru with flying colors.
Fast service, very decent pricing and was about 2 weeks from Japan to Montreal Can.
Their prices were less than 1/2 of what others were asking with superior shipping.
(4) Drums of Mixed Fabric Softener/Detergent (A51573)
(4) Drums of Mixed...
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
2016 Ram ProMaster 1500 Van, VIN # 3C6TRVAG2GE105143 (A51572)
2016 Ram ProMaster...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
