RimGuard Lifespan
/ RimGuard Lifespan #31
Personally I don't regularly check my tire pressure. The lugs of the tire should be flat on the ground all the way across. If the edges don't touch, pressure is to high. If the sidewalls bulge or the edges of the lugs are more than barely touching, your pressure is low.
Easy visual check to do. And more importantly easy enough to do you can do it when the load changes. Such as when picking up stuff in the loader or strapping something on the 3pt.
Just don't go above the Max pressure noted on the sidewall.
Cars have high speed & heat related issues to worry about necessitating much more rigorous tire pressure checking. Low pressure overheats tired & causes blowouts. It also creates lateral stability issues when cornering hard at speed.
Ballast liquid keeps the tires cooled on a tractor, not that they have the speed to heat the tires badly. And while there are lateral cornering forces, nothing on a tractor is "high speed".
/ RimGuard Lifespan #32
Its always interesting to watch how threads go in different directions and get off-topic from the OP.
I know RimGuard works. I know RimGuard is better than salt solutions. I know RimGuard requires a few extra steps to add air and check the pressure. I know RimGuard doesnt freeze until -35F. I know I can use standard glycol based anti-freeze solutions (ethylene or propylene) in lieu of RimGuard. I know I can even use some forms of windshield wiper solutions that wont freeze until -20F. I know there are tire foams that will work as well.
My question was regarding the lifespan of RimGuard and how long that product retains its original specs over time. Its been my experience that all liquid solutions eventually break down and lose their original intended characteristics, and at times even become harmful. Without some kind of confirmation from the manufacturer I dont think I could spend the money.
As one of the other comments mentioned, it is essentially in a "closed system" inside the tire. Once the air is used up, no break down should occur and the liquid is not drying out so it should generally remain the same as the day it was installed. If you need to replace worn tires, you should be able to remove it, replace your tires and re-install it. I have worked with Rim Guard and that has been my experience.
/ RimGuard Lifespan #33
OK - so I fired off an email to Rim Guard Corporate asking what the expected life span of the product is.
Their answer - - "Generally speaking, once Rim Guard is installed into a tire, it is in a sealed environment. This means no air or liquid can get into or out of the product so it will remain very consistent to its original state when it was installed. Hope that helps."
This reply was provided by a gentleman named - Craig - from Rim Guard Corporate.
/ RimGuard Lifespan
Thanks for your input, however I dont agree with that conclusion. Ive seen lots of things that were in sealed containers that broke down sitting on a shelf. Hence the term 'Shelf life", usually alluding to how long something will stay in its original state, even when sealed. Oxygen not being present doesnt always guarantee something will stay within its original specs. If that were the case you could buy a sealed barrel of gasoline and it would last forever, which we all know is not the case. Solutions and compounds often breakdown over time, I dont see where RimGuard would be exempt from that, so with that in mind Ive just been wondering how long before that product breaks down also. If it does remain the same forever, Id love to see the data supporting that, because that would be cool as heck how they got around Father Time. ;)
/ RimGuard Lifespan
Thank you sir ! Straight from the horses mouth as they say. :thumbsup:
/ RimGuard Lifespan #36
Let's see....I am 72 and my new B3350 hsdc has rim guard filled rear tires. If the lifespan is in excess of 20 years I am guessing that I probably won't know or be able to care if there is a failure and the tires start exuding a milk shake substance. Now, I wouldn't mind being around to observe that but hey let's be realistic. On to the next windmill!!!!!
/ RimGuard Lifespan #37
How long has Rimguard been around? I have had it in the rear tires of my B3030 since 2005. I don't think it was a new product then so there must be some history of it's performance for more than 10 years. Does anyone on here have any experience with it for longer than I have. The proof of how long it lasts is in real world use, not projected life span.
/ RimGuard Lifespan #38
Words of wisdom, Toolguy.
I hope the relevant party agrees.
My Hoe
/ RimGuard Lifespan
Thanks for sharing your experience. Have you seen the inside of your wheels in that 10 years time to see what the wheel looks like now? Again thanks for the input.
My Hoe
For sure that info of 10 years with the product is good first-hand info, Im grateful for anything anyone can share.
To be honest I find it interesting my inquiries are met with a bit of cynicism by many, I dont see why its heresy to look for verifiable facts before purchasing something as expensive as that stuff is and not rely on hear-say and/or sales pitches. But Ive ran into this same consensus on other forums with other things, boats, trucks, etc, so I guess its human nature.
/ RimGuard Lifespan #40
for my property, i have to deal with thorn trees and bushes. and then just some how finding a stinking nail some place. that causes a leak.
due to tire sizes are large enough, and more so heavy enough. it is easier for me to have equipment on hand to handle filling / unfilling the tires of a liquid. this is were my 30 gallon spot sprayer comes in hand with its 12v on demand pump. a few generic fittings, some valves, and a better tire nipple fluid filler fitting. and it can make your job easier dealing with tires. and all you need is the liquid you will be using.
to note it, when i end up getting a leak, from some thorn / nail. generally it means loosing almost half of the fluid before i realize it and get it back to the shed.
it really is not all that difficult to deal with filling up and or sucking out the fluid in a tire, it can be somewhat of a hassle initially (never doing it before) but after a couple times, you get things figured out and things lined up, and away it goes.
having a cherry picker / engine lift (not engine stand) can also help with removing tires and putting them back on. due to overall size and weight of tire and rim (when not filled with a fluid).
i realize your question is to life time of rim guard. but for me it is not life time, but is it cheap, is it safe when it leaks out from a puncture, and can i get it readily and quickly locally?
it can be rather dangerous running a tire half full of fluid. the fluid will splash a lot more inside the tire causing entire tractor to shake, vs getting the fluid 75% or so filled with fluid 75% is basically having vale located at 12 o'clock. and filling to point you are no longer getting air coming out as you put fluid into the tire. this helps keep the splashing down inside the tractor, and rim fully covered under the fluid. and it gives some air in the tire. to help allow tire to deform some as it rolls over the ground. and gives some shock absorbance.
again i am for DIY filling of tires, and just buying the fluid and putting it in yourself. it costs more up front getting things. but long run most likely cheaper and easier over all. more so when you do have to deal with a leak.
2023 Chevrolet Tahoe SUV (A59231)
2023 Chevrolet...
2014 Aerway Aerator (A55973)
2014 Aerway...
2023 CATERPILLAR 304 EXCAVATOR (A62129)
2023 CATERPILLAR...
GENERAC MAGNUM PORTABLE LIGHT TOWER (A59823)
GENERAC MAGNUM...
2015 Caterpillar CB24B (A60462)
2015 Caterpillar...
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
