Kabuki Tractor
I recently added Rim Guard to my BX2660 and thought I would share the information for anyone else who may find it interesting or useful.
Rim Guard dealers in Southwest Virginia is hard to find! Ended up driving 3 hours to the nearest dealer. Because of the distance and time constants I decided to buy the Rim Guard and install it myself. I took a 55 gallon plastic drum and three 5 gallon metal paint thinner cans and bought a total of 70 gallons of Rim Guard for $3 a gallon. I purchased the $9 liquid tire filling kit and the $4.50 3/4" brass valve stems from gemplers.com. I borrowed a 12V diaphragm sprayer pump that was rated at 2 gallons per minute and 45PSI. The pump worked great because I could push the Rim Guard under lots of pressure and not have to bleed the air out very often. I high recommend a garden hose shut off at the tire end of the hose. I bought a nice quality brass garden hose ball valve at Lowes for around $8 which allows you to easily close off your Rim Guard hose while bleeding air from the tires. The data below for most tires is about a 75% fill, pretty much level with the valve stem when it is at the top. Ignoring the controversy I loaded my front tires also. My thinking is it will help stability as you can't get weight any lower to the ground than in the tires. The R4 front tires are a little under 75%, and the front turf tires are a little over 75% filled. I plan to push snow with the turf tires and wanted all the extra weight I could add. I had no super accurate measuring equipment, measured the volume with a gallon jug and marked each gallon on the side of a 5 gallon pail, measured the weights with a digital bathroom scale. The Rim Guard I purchased was a little heavier than the advertised 10.5 pounds per gallon. A 5 gallon can weighted 59.8 pounds, and I'm guessing the can weighted about 1 pound, they are very thin tin cans. My calculations shows the Rim Guard to weigh around 11.75 pounds per gallon.
(all weights are in pounds and include the tire and rim assembly)
Tractor: Kubota BX2660
Front R4 (Industrial) tire: OTR Traction Master 18x8.50-10 (single tire and rim, not a pair)
Empty weight: 21.4
Loaded weight: 52.0
Weight added: 30.6
Rim Guard Used: 2.75 Gallons (slightly under 75% fill)
Rear R4 (Industrial) tire: OTR Traction Master 26x12.00-12 (single tire and rim, not a pair)
Empty weight: 50.8
Loaded weight: 179.6
Weight added: 128.8
Rim Guard Used: 11 Gallons (around 75% fill)
Front weight added 30.6 x 2 = 61.2
Rear weight added 128.8 x 2 = 257.6
Total weight added 61.2 + 257.6 = 318.8
Front Turf tire: OTR Grass Master 18x8.50-10 (single tire and rim, not a pair)
Empty weight: 18.6
Loaded weight: 57.8
Weight added: 39.2
Rim Guard Used: 3.5 Gallons (slightly over 75% fill)
Rear Turf tire: OTR Grass Master 26x12.00-12 (single tire and rim, not a pair)
Empty weight: 41.8
Loaded weight: 167.2
Weight added: 125.4
Front weight added 39.2 x 2 = 78.4
Rear weight added 125.4 x 2 = 250.8
Total weight added 78.4 + 250.8 = 329.2
(just for information)
Tractor: Woods front mount Zero-Turn diesel
Turf tire: Carlisle Turf Master 20x10.00-8 (single tire and rim, not a pair)
Empty weight: 20.6
Loaded weight: 83.4
Weight added: 62.8
Rim Guard Used: 5.25 Gallons (around 75% fill)
Total weight added 62.8 x 2 = 125.6
Empty weight: 21.4
Loaded weight: 52.0
Weight added: 30.6
Empty weight: 50.8
Weight added: 128.8
Empty weight: 18.6
Loaded weight: 57.8
Weight added: 39.2
Empty weight: 41.8
Weight added: 125.4
Empty weight: 20.6
Loaded weight: 83.4
Weight added: 62.8
