Rim Guard FYI
   / Rim Guard FYI #1
n8586m
Stanwood Mi
Kubota B2620 w/FEL
When I took delivery of my new B2620 I told the dealer not to load the tires as I wanted to try it without first, besides, he uses chloride. Well, after spinning my tires several times in the normally golf course quality lawn, and turf tires will dig a trench fast, I decided it was time to load.
I considered washer fluid but the best price I could find was 2 bucks a gallon and I need 44 gallons to fill the 33x12.5x15's. Add in the Gemplers filler and a drill motor pump I would be about 120 bucks.
I called a Rim Guard dealer for a quote and he said about 140 bucks. So I took it in today. First thing he says is the rubber valve stems will start leaking in about 6 months and I will be back with a real mess. Steel valve stems are 7 bucks each. That's a no brainer, put em in.
Total job took 3 hours and the final bill; 44 gallons of Rim Guard, 103 bucks, 14 bucks for valve stems, and labor to fill, remove tires and break them down to install the new valve stems 20 bucks for a total of 144 including tax. How cheap is that. Total weight about 460 lbs. Hope this is of some value to someone.:p
   / Rim Guard FYI #2
What will be of value to me is how effective it is for you. Are you running on any hills? I have a set of loaded turfs in the garage that I want to put on my Kioti but I'm worried it's still to wet. I have a serious hill out front and I don't want to loose traction going down hill. I have the FEL to stop me but that runs some serious risk of damage to the loader.
Look like you're in MI so the hill thing is probably a negative but I thought I'd ask anyway.
   / Rim Guard FYI
I do have a couple of small but steep areas. One is on the edge of the lake that I could slid into so we will see when I cut grass again, probably in three or four days. I will let you know if I stay out of the lake.:D
   / Rim Guard FYI #4
If NOT...then post on the SAFETY FORUM...:rolleyes:
Be careful out there...we need all the members we can get...:D
   / Rim Guard FYI #5
Is the price of rimg going down? That is a lot lower than the last quote I got (>$3 a gal for the fluid).
jb
5TH WHEEL PLATE (A53843)
5TH WHEEL PLATE...
2023 INTERNATIONAL MV607 21FT ROLLBACK (A54607)
2023 INTERNATIONAL...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A53422)
2017 Ford F-550...
