LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,257
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
I know that a lot of people go with what the manufacture suggests,Did some heavy loader work this past week and definitely felt that the tires were filled. All but confirmed it after bleeding the valve stems, but good to know nonetheless. In summary - dealer thought they only filled each tire with 10 gallons, but turns out they actually overfilled them. Good for me as I only paid for 10 gallons in each tire. Thanks for the help everyone.
Kioti finally got back to me on recommended pressures for R14 tires on their CK series tractors. They recommend between 23 and 29 psi for both the front and rear, and closer to 29 psi for the front if using a front end loader.
but I'd think that the 23 to 29 psi in the rear would be with a tractor being used with the max allowable weight on the rear axle.
That is very seldom the case, From what I've read and seen most R14's are 6 or 8 ply tires.
If these are your tires they are rated for over 4000# per tire at 30 psi.
If they were mine I'd be trying down around 15 psi and looking for a decent sidewall bulge and the longer foot print on the ground.
But it is an individuals preference and what they want for performance from the tractor and how the lead lag is on the tractor as varying the tire pressure will effect the lead lag ratios.
