Ballast Rim Guard and punctures
   / Rim Guard and punctures #1
joea99
Platinum Member
Marbletown NY
Kubota B21, JD 240GT
If using Rim Guard, can tire be plugged and have it hold? Currently the Ag tires on a machine I bought used are plugged. Maybe a newbie mistake, but I never thought to check, or ask. Anyway, after 2 years of use, still holding.
But, am considering loading tires. Local shop only does calcium with inner tubes. So looking at Rim Guard. Can a tire be safely plugged when filled with Rim Guard?
   / Rim Guard and punctures #2
Beet Juice is a food product. After one or two months in the heat Rim Guard is nasty for any tire shop to deal with and you pay for tire service accordingly. You may be willing to pay for Rim Guard's density but consider carefully before proceeding.
I recommend water and alcohol for loading tires.
T-B-N ARCHIVE: https://www.tractorbynet.com/forums/owning-operating/179606-rimguard-vs-methanol.html
Filling rear tires is a project you can do yourself. Less effort to fill rear tires in your driveway than trailer tractor or deliver wheels/tires to a tire shop.
U-Tube Videos: https://www.youtube.com/results?search_query=Filling+loading+tractor+tires
   / Rim Guard and punctures #3
I would think you would roll the hole to 12 o’clock position to plug it.
Tried Rim Guard in 2 different machines and it’s a mess. I strongly recommend wheel weights.
   / Rim Guard and punctures #4
Another vote against Rimguard. Nasty, smelly stuff after a while. I am not aware of any concerns plugging tires containing liquid ballast. As suggested, rotate the tire so the leak is above the ballast. Allow sufficient cure time before moving.
Plugging tubed tires does not work often and tubing tires that have been plugged requires that the plugs be cut/ground off smooth with the tire inner surface. Tubing plugged tires generally is not a good idea.
Interesting links. A lot simpler DIY than I thought.
   / Rim Guard and punctures #6
One good thing about rim guard, it wash's right off with water and a little soap. The smell is the only down side besides being sticky.
   / Rim Guard and punctures #7
I've had Rim Guard in my 2009 Kubota M6040 tires for eleven + years. No problems. Perhaps, around here, they put something in with the RG. I got a short blast a year ago - checking tire pressure. It was sweet, sticky but no way was it nasty. It was still plain 'ol beet juice.
   / Rim Guard and punctures #8
I replaced the outer valve on my rear rimgard filled tire. Some leaked out and it wasnt very smelly at all. The stuff has been in there for 10 trouble free years before a branch damaged the valve.
   / Rim Guard and punctures #9
Did it taste like beets?:licking::licking:
   / Rim Guard and punctures #10
If you have a big leak and it’s a hot day, it’ll kill any grass in the area. I don’t care how safe the label says it is, liquid in a black tire on a hot day is going to burn grass.
When I had a big leak, it killed the grass and smelled like skunk.
I guess everyone has different results.
2018 ADDCO ROAD SIGN DH1000-ALS (A45046)
2018 ADDCO ROAD...
2013 FREIGHTLINER CASCADIA(INOPERABLE) (A45046)
2013 FREIGHTLINER...
2015 INTERNATIONAL LONE STAR SLEEPER (A43004)
2015 INTERNATIONAL...
1998 CPS TRAILER COMPANY BELLY DUMP TRAILER (A45046)
1998 CPS TRAILER...
2003 John Deere 310SG 4x4 Extendahoe Backhoe Loader (A42742)
2003 John Deere...
2016 Ford Explorer AWD SUV (A44572)
2016 Ford Explorer...
