Rigid hydraulic line question
/ Rigid hydraulic line question #1
TheSheriff
Grants Pass, Oregon
Jinma 284
Have a leak on my Jinma 284 FEL rigid hydraulic line. The leak is at a joint where the rigid tube is fused to a "block". This "block" is what the FEL rubber lines are threaded to... hope that makes sense. My question is how is this joint joined? Welded? Brazed? I'm trying to weigh my repair/replace options.
Thanks, Brad
/ Rigid hydraulic line question #2
Without a picture, I have to assume this is a transition piece you are talking about. The hydraulic circuit(s) continues in the same path as the steel tubing lines into hoses. Correct? Some are welded and some are sil-brazed. Hard to tell without a picture, but usually welded joints will have a small radius bead around the steel tubing whereas a sil-brazed joint will not have the radius bead.
Thanks Bob. On closer inspection, mine appear to be brazed, so I'll attempt the repair myself. I wasn't sure last night as it was getting dark and some robot welds are pretty smooth these days (Not that a robot has ever touched a Jinma :)
/ Rigid hydraulic line question #4
I wouldn't attempt to re-braze with brass brazing rod if that's what you had in mind. If you are sure it's a brazed joint, here's some tips.
SILBRAZE
/ Rigid hydraulic line question #5
I use 56% silver braze another member was successful with a silver braze in the mid 40's. Use a good paste flux. I have used both white and black depending upon the diameter of the fitting.
/ Rigid hydraulic line question #7
2022 EZ-GO ELITE...
2022 CATERPILLAR 313GC EXCAVATOR (A65053)
2022 CATERPILLAR...
2018 GRASSHOPPER 900D MOWER (A66091)
2018 GRASSHOPPER...
HORST RSW HEADER CART (A64278)
HORST RSW HEADER...
40' High cube 6 door Single use Shipping Container (A64194)
40' High cube 6...
2007 30ft. Regal 30 Express Cruiser Boat with 2010 Vantage T/A 33 Ft. Trailer (A64557)
2007 30ft. Regal...
