Rigid hydraulic line question
/ Rigid hydraulic line question #1
TheSheriff
Grants Pass, Oregon
Jinma 284
Have a leak on my Jinma 284 FEL rigid hydraulic line. The leak is at a joint where the rigid tube is fused to a "block". This "block" is what the FEL rubber lines are threaded to... hope that makes sense. My question is how is this joint joined? Welded? Brazed? I'm trying to weigh my repair/replace options.
Thanks, Brad
/ Rigid hydraulic line question #2
Without a picture, I have to assume this is a transition piece you are talking about. The hydraulic circuit(s) continues in the same path as the steel tubing lines into hoses. Correct? Some are welded and some are sil-brazed. Hard to tell without a picture, but usually welded joints will have a small radius bead around the steel tubing whereas a sil-brazed joint will not have the radius bead.
Thanks Bob. On closer inspection, mine appear to be brazed, so I'll attempt the repair myself. I wasn't sure last night as it was getting dark and some robot welds are pretty smooth these days (Not that a robot has ever touched a Jinma :)
/ Rigid hydraulic line question #4
I wouldn't attempt to re-braze with brass brazing rod if that's what you had in mind. If you are sure it's a brazed joint, here's some tips.
SILBRAZE
/ Rigid hydraulic line question #5
I use 56% silver braze another member was successful with a silver braze in the mid 40's. Use a good paste flux. I have used both white and black depending upon the diameter of the fitting.
/ Rigid hydraulic line question #7
2025 METALIUM INDUSTRIES 14 T/A GOOSENECK ROLLOFF TRAILER (A60736)
2025 METALIUM...
2022 John Deere 1025R (A53317)
2022 John Deere...
Chevrolet 2500 Flat bed (A61307)
Chevrolet 2500...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2013 GREAT DANE 53X102 T/A REFRIDGERATED TRAILER (A59906)
2013 GREAT DANE...
2020 Chevrolet Silverado 5500HD Dump Truck, VIN # 1HTKHPVK0LH288017 (A61165)
2020 Chevrolet...
