Right Tool for Mowing Bumpy Ground - SCUT, Small CUT or ZTR
   / Right Tool for Mowing Bumpy Ground - SCUT, Small CUT or ZTR #1
Poopdeck Pappy
Elite Member
Dallas, Texas
Kioti DK50SE Cab, Kubota BX23, Kubota BX2660, Grasshopper 729BT
I have a 2.5 acre lot that I own, where I intend to eventually build a home. I've been mowing it with a John Deere GT235 garden tractor. But the ground has crawdad mounds and holes where my neighbor's cows clomped around when it was wet, and it's a rough ride on my GT.
The property is a mix of about 20% bermuda and 80% johnson grass and weeds.
I'm trying to decide whether the right tool for mowing it is a BX, a B or a ZTR. I'd really like to have a ZTR, but I'm afraid the rough ground will beat it to death. I'm not sure a BX will ride any better, though, since they have small wheels also.
Also, does a front-mount ZTR ride any better than a mid-mount on rough ground?
Footnote: I have a Kioti DK50 and a BX23 at my 30 acre property, but this 2.5 acres is not close enough to my 30 acres to trailer one of those tractors to the 2.5 acres every couple of weeks.
   / Right Tool for Mowing Bumpy Ground - SCUT, Small CUT or ZTR #2
Re: Right Tool for Mowing Bumpy Ground - BX, B or ZTR
Might be worth trailering the Kioti there and spending the day re-grading the lot. I think that you could make 2.5 acres pretty smooth with a box blade and some patience, then you'd have to re-seed all the lawn you'll have torn up. A pain, but it would beat suffering through a bumpy mower ride every week for the rest of your days.
   / Right Tool for Mowing Bumpy Ground - SCUT, Small CUT or ZTR #3
Ditto. Look at Ratchet Rake attachment for your loader for smoothing and prepping.
   / Right Tool for Mowing Bumpy Ground - SCUT, Small CUT or ZTR #4
The smoothest ride would be on a UTV or ATV pulling a trail mower.
   / Right Tool for Mowing Bumpy Ground - SCUT, Small CUT or ZTR #5
I agree with most of the above, a tiller and lpgs would smooth it up ready to replant. Then use a ztr and cut your mowing time to an hour+.
   / Right Tool for Mowing Bumpy Ground - SCUT, Small CUT or ZTR #6
I agree with the above about smoothing the ground out first. If you don't, it's always going to be a rough ride mowing and you'll beat your equipment to death. The BX will be a slow mow because of it's speed or lack of. Mow with the DK and a rear finish mower, done in no time. Or a zero turn if you have the bucks.
Well, of course you guys are right about smoothing out the land. I have the tools to do that, and I will. But the dang crawdads will rebuild their mounds with the first rain. And I pray the neighbor's cattle don't get out again after a rain.
So, let's assume it gets smoothed out but not as smooth as a lawn. Which one is going to give me a better ride - a SCUT or a ZTR? I've got a BX23 (no MMM), so I know those small wheels are somewhat rough riding (although better than the even smaller wheels on my GT235).
A larger commercial ZTR will have drive wheels about the same size as the ones on my BX.
   / Right Tool for Mowing Bumpy Ground - SCUT, Small CUT or ZTR #8
I think that some of the newer zero-turns have a suspension. That might make mowing the bumpy stuff more tolerable.
   / Right Tool for Mowing Bumpy Ground - SCUT, Small CUT or ZTR #9
Ferris ZTRs have a reputation for their suspensions. I haven't used one, so I have no personal experience.
Steve
   / Right Tool for Mowing Bumpy Ground - SCUT, Small CUT or ZTR #10
Patented Suspension Zero Turn Mower Models | Ferris Commercial Mowers
Suspension system consists of rear coil-over-shocks with dual cast-iron maintenance-free suspension arms (shown) and front independent adjustable coil-over-shocks.
Call your dealer, ask for a demo on your place, then you will know for sure. :thumbsup:
2023 BOBCAT T66 R-SERIES SKID STEER (A52705)
2023 BOBCAT T66...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
Leeboy 8500 Paver (A47477)
Leeboy 8500 Paver...
2001 MACK CX SLEEPER (A54313)
2001 MACK CX...
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A54313)
2003 VOLVO VNL...
UNUSED FOLDING WAGON (A54757)
UNUSED FOLDING...
