Right to Repair.
   / Right to Repair. #53
Playing devils advocate, if you were the CEO at John Deere and your IT division spent years and millions of R&D dollars developing the software for the "digital future of farming", would you want to give it away so that your foreign competitors can copy it and sell it dirt cheap?
The same goes for more tame software for the fuel mapping (for example) of a tractor. The software took significant time and development hours. Giving it out to customers does them very little good (who really can reprogram the computers) but opens the manufactures up to theft of intellectual property that can be reused in knock-off products.
Right to repair is not giving away engine control software! Or any of the software running the tractor or that could be used by competitors.
I'm not sure why the manufacturers are fighting back with the liability thing. It' probably possible, but pretty unlikely. I just don't see a lot of demand for hot-rodding a combine or such vehicle. Nor do I think that a gaff made by a farmer re-programming his tractor will even allow it to operate.
That being said, they need to be better prepared to either provide cost effective service on demand or simple plug and play components that satisfy both the manufacture and the customer. I'm of the repair-it-yourself group. But I've never reprogrammed a vehicle computer.
Right to repair as far as software goes means the manufacturer has to make repair information and interfaces available. Like OBD2 for cars. There are a standard set of error codes that the car emits in a standard protocol. (actually there's like 4 or 5 OBD2 protocols but that's another problem). OBD2 was the best thing that came out of emissions regulations besides the reduced emissions themselves. It's not nearly standard enough. I still have to have different software for each make of car/truck I own because most of the detailed interesting stuff is manufacturer specific.
Another repair right is the right to buy parts and have work done the mechanic of your choice, or by yourself. Most car and truck makers do that (Moss-Magnusen act requires it for auto warranties. Tractors are not subject to that act). Tesla being one partial exception. Also consumers should not be forced into a shrink wrap type license where they don't actually own the car or tractor they bought. If we had effective consumer protections that stuff would be illegal.
Big ag tractors are more complex than cars so the laws would have to take that into account. But as it is now Deere is leading the way towards a model where the manufacturer controls all and the customer has no rights. I'll never own another Deere (or ever a Tesla) as long as they follow this anti consumer model.
I have reprogrammed ECUs. Turbo cars are fun that way, you can make a lot more power. Or blow them up if you're not careful. Of course then it's your fault and the company would know from the ECU.
   / Right to Repair. #54
Deere will sale a license to their diag. software to use on a laptop. I work with a Deere dealer. However, that software does not give the end user to right to reprogram an ecu. The dealers can not reprogram an ecu without going thru Deere. Mostly due to the EPA. We can't sell you an old rebuild engine without turning in an old engine block.
EPA doesn't want you to replace a new tier 4 engine with one before their stuff. This is being driven as much by our government telling us what we can do, as it is by the corporations. I still remember the old days when I parked my old car at the top of the hill, so it could roll down to start it. I couldn't afford a new battery. And more than once have pull started a tractor.
   / Right to Repair. #55
All the diagnostic and adaptation software could be in the tractor with a easy to use interface for customers. A simple conversation with a service manager and the right parts could be waiting at the dealership with the farmer being enabled to install the parts. Right now farmers are being held at ransom by some tractor manufacturers. I have very little sympathy for equipment manufacturers. This isn't any thing but about money with very little regard for the farmer who needs to get his crop off.
   / Right to Repair. #56
[snip]
Another repair right is the right to buy parts and have work done the mechanic of your choice, or by yourself. Most car and truck makers do that (Moss-Magnusen act requires it for auto warranties. Tractors are not subject to that act).[snip]
Ericm979, curious why you say that our CUTS are not subject to the Magnuson-Moss Warranty Act? In what way are they not "consumer products", and we not "consumers" buying them for personal use? :shocked:
   / Right to Repair. #57
It is not that simple. I agree that customers are being held hostage, but the issue is even if the farmer installs the parts, the dealer has to flash the ECU so it will recognize the new parts in some cases. And this is not limited to just JD tractors, Try automobile from all the manufactures, but also Husqvarna and Stihl products. With the new advances in lawnmowers and EFI with some of the new units now using CAN bus systems. You now have to have 2 separate diagnostics software packages, one for the engine and one for the mower. And the EFI software for the engine is not an OBD type system. Each mower engine manufacturer has their own software.
   / Right to Repair. #58
What you say is true but all of the software necessary for flashing the ECU could be in the ECU. All the diagnostic software packages could be built into the equipment that needs it. If it was designed properly the dealer wouldn't even need to come to the equipment.
   / Right to Repair. #59
The issue with Deere and others with software is they don't want to expose the goods to the public. Do you think Tesla would be OK with unlocking the software for everyone to see? That is never going to happen without a court battle. I'm thinking this thing with Deere is being pushed by people looking for a money making opportunity selling reprogram kits that might even cause damage to the tractor. If a Deere blows up out in the field, who's reputation gets damaged, Deere or the software company that the farmer had work on the tractor?
No, this is being pushed by people buying a product and then being told it's not theirs to be worked on as they wished.
In automotive with the OBD standard readers can read error codes and provide guidance on what is going out.
As far as it being too technical for the owners and mechanics that is pure bull,
I have had code readers and scanners for years and even if I go to the dealer for warranty work after a CEL I have scanned it and have a good idea of the issues.
And to other posters , manufactures not wanting to expose the software so other manufacturers can copy it, that's also bull.
Any one with the resources to build one has the resources to clone copy and modify the software.
Leasing the parts that operate a piece of equipment is theft, if I buy it belongs to me, if I want someone other then the manufacture to work on that is my right and to make the interfaces that need to be accessed propitiatory should be criminal.
   / Right to Repair. #60
Your on the wrong side of history though.....
Sorry, Right to Repair Advocates: You may be right, but John Deere is on the Winning Side of History — Janzen Ag Law
2017 Ford Expedition (A56859)
2017 Ford...
PumpJack Brand Pump Jack (A56435)
PumpJack Brand...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
40006 (A55788)
40006 (A55788)
2018 John Deere 30G Mini Excavator (A56857)
2018 John Deere...
2007 Ammbusher DL66 Hydraulic 66in Brush Cutter Skid Steer Attachment (A55973)
2007 Ammbusher...
