Rotary Cutter Right size rotary cutter for a Kubota L4400
   / Right size rotary cutter for a Kubota L4400 #11
I am new here, but not to tractors and cutter use.
My experience is that a cutter wider than my tractor track, in among'st trees, "will" get me trapped. It's hard enough with a cutter just a little narrower than the tires.
Also, I don't want the frame work of a cutter "under" the deck. This set-up will trap objects between the blades and frame. I want the underside of the deck smooth, so larger objects can easily be slung out. I also, want a cutter with deep sides, for the same reason.
I don't know what the PTO HP is on your tractor, but for a 50 HP out-put tractor I recommend medium duty cutter in 6' or heavy duty cutter in a 5'.
My brand of choice is "Rhino"
I have a Massey- Ferguson 255. I just bought a Rhino 172 cutter for it.
Mule
   / Right size rotary cutter for a Kubota L4400 #12
I turn the mower upside-down and sharpen the blades w/ an angle grinder 2x/ season.
Just curious, how do you turn the mower upside down? I would like to do that to sharpen the blades but don't want to damage anything.
   / Right size rotary cutter for a Kubota L4400 #13
I have a Kubota L4400 and I use a medium duty King Kutter Rotary mower and the tractor handles it very well I would not hesitate to put a 6 foot mower behind your machine. Mine is a Hst model and if by chance you think it is bogging down (I have only experienced bogging down in tall thick hay)just roll back on the pedal and slow down a bit. I have been satisfied with the machine so far, but I only have 66 hours on it up to this point.
2018 Ford F350 (A55973)
2018 Ford F350...
2016 Freightliner Bucket Truck (A55973)
2016 Freightliner...
2018 TowMaster T-12D T/A Flatbed Trailer (A55853)
2018 TowMaster...
2015 Toyota Highlander XLE SUV (A56859)
2015 Toyota...
2007 FREIGHTLINER M2 26FT BOX TRUCK (A57880)
2007 FREIGHTLINER...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2013 Chevrolet...
