Right Side Flasher/Turn Signal Out
   / Right Side Flasher/Turn Signal Out #1
x703jko
Maryland
Kubota BX24TLB
My right side flasher and turn signal (both) are out. Hence, I doubt it's the bulbs.
I checked the quick connect connections near the lamp housing and they appear to be seated properly.
Before I start tearing the tractor down and start tracing circuit continuity, is there something else I can check?
Note, the left side flasher/turn signal is working so I don't think it's the fuse.
Thanks!
Jeff
   / Right Side Flasher/Turn Signal Out #2
If your right side flasher is grounded by a wire at the light mounting point or near by, I would check to make sure the ground is to clean bare metal.
Hmm...I don't recall seeing that it was grounded on the circuit diagram in the service manual...I'll check again and let you know what I find.
Jeff
   / Right Side Flasher/Turn Signal Out #4
Jeff,
One other thing I would suggest is check the socket for corrosion. Also swap the bulb between sides to ensure it is not a bad bulb.
gator said:
Jeff,
I'll check and let you know what I find. Jeff
40ft High Cube Shipping Container (A57453)
40ft High Cube...
11' Container W/Side Door and Window (A57149)
11' Container...
2014 VOLVO VHD DAYCAB (A58214)
2014 VOLVO VHD...
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A52707)
2004 EAGER BEAVER...
20' Sea Container (A55272)
20' Sea Container...
2018 Ram ProMaster 2500 Passenger Van (A56858)
2018 Ram ProMaster...
