Right Side Flasher/Turn Signal Out
   / Right Side Flasher/Turn Signal Out #1
x703jko
Maryland
Kubota BX24TLB
My right side flasher and turn signal (both) are out. Hence, I doubt it's the bulbs.
I checked the quick connect connections near the lamp housing and they appear to be seated properly.
Before I start tearing the tractor down and start tracing circuit continuity, is there something else I can check?
Note, the left side flasher/turn signal is working so I don't think it's the fuse.
Thanks!
Jeff
   / Right Side Flasher/Turn Signal Out #2
If your right side flasher is grounded by a wire at the light mounting point or near by, I would check to make sure the ground is to clean bare metal.
Hmm...I don't recall seeing that it was grounded on the circuit diagram in the service manual...I'll check again and let you know what I find.
Thanks
Jeff
   / Right Side Flasher/Turn Signal Out #4
Jeff,
One other thing I would suggest is check the socket for corrosion. Also swap the bulb between sides to ensure it is not a bad bulb.
gator said:
Jeff,
I'll check and let you know what I find. Jeff
2015 FREIGHTLINER CASCADIA DAYCAB (A58214)
2015 FREIGHTLINER...
2023 Sun Tracker Pontoon Boat (A56859)
2023 Sun Tracker...
Survey Kit (A57149)
Survey Kit (A57149)
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
12ft x 20ft Steel Carport (New/Unused) (A59225)
12ft x 20ft Steel...
2017 Kubota M7-151 Premium MFWD Tractor (A56438)
2017 Kubota M7-151...
