Right Rear Wheel Area-Grinding Noise?
   / Right Rear Wheel Area-Grinding Noise? #1
gdrew
Vancouver Island, BC
Branson 2400h
Hi All,
I'm getting a very distinct metal on metal sound coming up from my right rear wheel area on my Brandon 2400h. The sound seems to be most prominent when turning in either reverse or forward. I didn't notice the noise last year prior to putting fluid ballast in the rear tires so not sure if the extra weight is making it more noticeable. It sounds like a car wheel bearing that is going bad. Just wondering if anybody has had this same issue and what the culprit was?
Thanks!
   / Right Rear Wheel Area-Grinding Noise? #2
split the brake pedals and see of one side is more grabby than the other
   / Right Rear Wheel Area-Grinding Noise? #3
Yes - perhaps the brakes. One is dragging or has a buildup of "crud".
   / Right Rear Wheel Area-Grinding Noise? #4
It may be farfetched but did you engage the differential lock and it has failed to disengage?
a) Okay, I'll split brakes this weekend when I have time and see if I can get a different result.
b) Its very clean in that area so not likely dirt, but anything is possible, I'll follow-up this weekend.
c) I have had a very difficult time getting the differential lock engaged in the past and it never seemed to stayed engaged.
Thanks all!
   / Right Rear Wheel Area-Grinding Noise? #6
Thanks all!
Not familiar with the 2400 but my 4720 differential lock needs to be pressed continuously to stay engaged.
   / Right Rear Wheel Area-Grinding Noise? #7
Mine too.
   / Right Rear Wheel Area-Grinding Noise? #8
Jack up side making noise spin tire.
Unused Delta Crash...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2017 Rogator RG1300B Dry Fertilizer Applicator (A51039)
2017 Rogator...
2000 INTERNATIONAL 4300 17FT ROLLBACK TRUCK (A51222)
2000 INTERNATIONAL...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
