Right hand 3 point lower hitch arm
   / Right hand 3 point lower hitch arm #1
cabover4us
Back in Salem, New York
1987 john deere 855 sold and bought a YT235 Yanmar, love this tractor
This past week was a working vacation, some heavy work some light. Took off my backhoe off of my Yt235, and having trouble with the right hand arm pin that connects 3 point hitch to tractor, it's so tight I can barely push it in and out. And of course you can only use the tips of your fingers to start the process after removing the snap locking clip. Left side you can move smooth as silk. So not sure if I need a new pin and socket for the right side arm. Anyone else have issues with the lower arm pins on their Yanmar.
One sidebar is, if I do need a new pin and socket I have to jack up tractor remove rear tire (which are loaded) because there is no pin clearance towards the steel rim.
I have an oops to report, 3 month ago I decided to take backhoe off, needed some york rake work. Was able to use vice grip to grab pin end and gently tapped on vice grip to move pin out, worked relatively well. After the work dropped attachment and proceeded to investigate pin problem. Removed arms, pin was stiff as a board. Cardboard under and blasted pin and socket full and covered with lubrication plus rubbing oil in and on pin, after this exercise the pin slide like on ice. So I am embarrassed.
   / Right hand 3 point lower hitch arm #3
Don't think you're alone.
An aside to that I noticed one of my lower 3 Pt arms was missing the square turn buckle. The left arm, drove to South Glens Falls to Emrick Sales and Service. They had them in stock, but they had the original smaller ones, the ones I need are longer the squared part is like almost 2 inches longer. This problem originated from using 3 point hitch arms all connected up they hit the heavy bracket for backhoe mount. Going down it won't quite hang up but the implament catches and jerks going up or down hitting the bracket. Parts man brings bag out it's the smaller versions. I did tell him I have a plastic bag the new ones I got before so I would have to go home call back with info. Well wrong number.
I did search on Tractorbynet and I found emails from Yanmar Corporation about this very issue. Recall says you get new longer turn buckles and new lifting links.
Called left message, spoke of recall information.
Should get off my duff and call to see if any results were discussed.
Okay, I hit send before I realized I wasn't done with that last post. More info.
OK this is called a Warranty Update.
Top of Form
YT235TLB and B75 Backhoe Kit Lift Link and Safety Label Update-Mandatory
Issue No. U-DD17-00158
Product Category Tractor
Revision history New
Administration Number YATB2017-001-A
Bulletin Category QA Service Bulletin
Issued date of the original news Fed 17
2017
Last Updated May 26, 2017
Model B75-YT2P-KIT, YT235
Contents
Affected Models:
YT235 Tractor with Loader and Backhoe
(TLB Model) Mandatory
B75-YT2P-KIT, Backhoe DOP Kit for YT235 Mandatory
Symptom or Situation :
1. There is a risk of interference between lift link and backhoe bracket.
2. After backhoe bracket installation, the
original safety label on PTO guard will be hidden.
Procedure :
1. Replace the turnbuckle and apply safely label to specified location below.
*1A8405-74500 TURNBUCKLE (Qty 2)
*1A8330-65620, LABEL, DANGER SHAFT
2.B75 Backhoe DOP Kit ONLY:
Replace LIFT LINK ASSY L and R in addition to step 1
*1A8405-72351 LINK ASSY LIFT L (Qty 1)
*1A8405-72151 LINK ASSY LIFT R (Qty 1)
3.After the rework, submit a warranty claim for each affected unit through the
e-Claim system for reimbursement by following the warranty reimbursement terms of
YATB2017-001-A
I wasn't able to figure out how to add pictures and documents so I typed it out, hope someone can use this info.
When this was brought to the attention they handed me a heavy bag with new turnbuckles nothing else. So here we go again. Yes completely my fault in losing one turnbuckle I can and will pay for those but the new links should be on them as the links were never handed over to me other than bag of turnbuckles.
The picture of information on my post was given to one of the branches of Emrich Sales and Service. Charlton and South Glens Falls were sold to Salem Farm Supply so the Emrichs in Melrose, NY is the only Yanmar around our area that I know of.
Anyway parts people are tracking this for me with Yanmar. Holding out hope this gets resolved.
I lost one of the adjustable chain links on 3 point lower arms, I will purchase those as I admit losing one.
But the lifting links should have been included, those should be free.
Keep you posted.
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
2017 Chevrolet Traverse LS SUV (A55853)
2017 Chevrolet...
2017 Jeep Patriot 4x4 SUV (A53424)
2017 Jeep Patriot...
