Riggin' for steep slopes
   / Riggin' for steep slopes #31
Re: Riggin\' for steep slopes
Brad & Bird, thank you for the info. Guess I have never looked that close or it is another one of the things I forgot. That seems to happen more and more.
MarkV
   / Riggin' for steep slopes #32
Mark,
They were kind of hard to find. They look exactly like the normal tire gauges and the package looks identical. I missed them the first time I looked.
--Brad
   / Riggin' for steep slopes #33
<font color=blue>filling a tire solid w/ foam would cause a slightly rougher ride as the ability of the tire to compress under load is removed</font color=blue>
The term "foam" implies to me that the material is composed of many small cells, which themselves are filled with air or some kind of gas, which would still allow for a certain amount of compression. I have dealt with "open cell" (air can flow from one cell to the other) and "closed cell" (each cell is sealed) foam materials in other applications, but I have no idea what kind of foam goes into a tire.
Since my tractor is located way out in the boonies, and I have no trailer (or sufficent truck to pull it with), I am warming up to the idea of flat-proofing my tires with a foam fill. Can anybody tell me more about the characteristics of these foams? Does the material wind up rigid, or is it somewhat elastic (spongy)? If it truly prevents flats, I'm assuming it is a closed cell foam.
   / Riggin' for steep slopes #34
On the original thread, what about outriggers? Sort of like what they put on canoes for open water use. At first I thought it was a ridiculous idea, but now I wonder... Would it be possible to rig up an axle, say 4 feet wider than the tractor, then have it mounted under the frame? An appropriately sized wheel on both sides would widen the footprint of the tractor a great deal. Some sort of magic solution would be nice. Almost half of the property I am dealing with is too steep for the tractor (at least with me driving it), and a lot of it is too steep even for my ATV.
Kevin
   / Riggin' for steep slopes #35
well, i like not to replace intertubes and or patch tires every week. we do many acres and since last year when we started with slime, we almost fergot how to take apart these small tractor tires, we rather work than play tire mechanic.
   / Riggin' for steep slopes #36
The foam does end up being solid. The tires don't flex.
   / Riggin' for steep slopes #37
One brand of foam, I can't remember which, is advertized to come in hard, medium and soft.
   / Riggin' for steep slopes #38
Just a thought but if the slope is steep enough to make one think of outriggers perhaps one should be thinking of just keeping the tractor off of it. There are limits.
Egon
   / Riggin' for steep slopes #39
Egon,
You are, of course, correct. I was just speculating. I think before I would attempt anything like outriggers, I would go investigate one of the PowerTrac machines others rave about. They seem more suited to this kind of thing than a tractor. I almost wish I had known about them before I got the tractor bug, but not quite :) Maybe in addition to the BX? Being single without kids does have some perks.
I took my BX on an exploration tour of part of the hill, which I am already intimately familiar with from ATV journeys. I went only straight up/down the hill, but I did turn it around in what I thought was a pretty flat spot near the woods (it seemed flat on the ATV). Anyway, I ended up doing a lot of small maneuvers to try to keep from turning across any steep spots, and finally got it back down. The load of sand I was able to get into the bucket wasn't worth the trip (about two grain shovels full. I just wanted to get back down at that point). Without any great technology breakthrough, or perhaps discovering a flaw in the laws of physics, the tractor will not be going back up there. For that, I can load the trailer and pull it behind the ATV, which is what I've been doing. At least loading the cart should be easier now.
The guy we hired to help spread mulch initially had a really big (yellow) JD backhoe/front loader. He also had a NH compact, I think it was a TC29D. For this particular stretch he used the NH, because he said the JD might crush the septic tank, which is up there somewhere. He went only straight up/down, but the NH handled it, and he didn't seem too nervous about it. Although I did watch him get the big JD almost off the wheels and bouncing a bit on another spot. He said "no problem", but I wonder if that's true or not. I certainly wouldn't want to have been on the thing at the time. Between him moving the bulk around into piles, and 2-3 of us doing the final spreading, we managed to do a little over 350 yards of mulch in 3 days (and I hope we never have to do anywhere near that much again).
Kevin
   / Riggin' for steep slopes #40
I would use the slime or equivalent for puncture resistance. There is also another product that uses similar technology, with micro-fibers... works great in car tires too.. I saw a demo at a tire shop.. they had a mounted tire in the salesroom on a post.. with an air gauge attatched, and a box of nailes and a hammer... ther must have been 20 nails in it... pull em out ( soooooop! ) and it seals... looked neat
soundguy
""Poster: Harv
Subject: Re: Riggin' for steep slopes
The term "foam" implies to me that the material is composed of many small cells, which themselves are filled with air or some kind of gas, which would still allow for a certain amount of compression. I have dealt with "open cell" (air can flow from one cell to the other) and "closed cell" (each cell is sealed) foam materials in ""
2015 Nissan Altima Sedan (A54815)
2015 Nissan Altima...
2018 TowMaster T-12D T/A Flatbed Trailer (A55852)
2018 TowMaster...
2021 WACKER NEUSON LIGHT TOWER (INOPERABLE) (A55745)
2021 WACKER NEUSON...
2005 Autocar WXR Heil Rear Loader Garbage Truck (A55852)
2005 Autocar WXR...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A55851)
2016 Godwin CD150M...
2012 CATERPILLAR 305DCR EXCAVATOR (A52707)
2012 CATERPILLAR...
