rhino radiator fan dead???
   / rhino radiator fan dead??? #1
TOMMYHPX4X4
schriever, louisiana terrebonne parrish
gator hpx 4x4
the radiator fan on my new rhino ain't workin no more?? anybody got any ideas? i'm gonna call the dealer tomorrow to see what they say i hope i can fix it at home and not have to bring it in.
   / rhino radiator fan dead??? #2
Mine did that once. My issue was the plug for the fan was getting moisture in it. This may or may not be your issue. I discovered this by accident. I'd unplugged the fan planning on taking the fan out and then ended up getting busy and didn't get back to it for a day or so. By then I wanted to use it, so I just plugged it back in and, oddly enough, it worked fine. I took the plug apart again, cleaned it, and then sealed it after I plugged it in again. I never had a problem again. I have no idea if this will help you, but it worked for me.
i got power at the fuse but no power at the plug for the fan?? i tried unplugging it and checking for water but it's dry. i called the dealer and they told me they want me to bring it in but that it will be a week or so before they can get around to it. so it looks like the new rhino is dead for a while . sorta reminds me of the hpx. right after i got it i had a factory defect on the carb and had to bring it in but they fixed it in a few hours.lol
New Long Forks (A53002)
New Long Forks...
2010 HEIL TOKEN TRAILER (A52472)
2010 HEIL TOKEN...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
INGERSOLL RAND G70 GENERATOR (A52472)
INGERSOLL RAND G70...
