Rhino Gear Box Lube?
/ Rhino Gear Box Lube? #1
VT365
While doing a PM on my Rhino rotary, I noticed the gear box contained grease. I was expecting to see heavy gear lube. Is this the norm for bush hogs? The grease was also about 1-2 inches below the check plug. Should I top it off?
It's is new with only about 10 hrs of use.
/ Rhino Gear Box Lube? #2
Grease does have to expand and release heat so filling it to the top would only hold the heat in and prematurely break down the properties of the grease.
/ Rhino Gear Box Lube? #3
This is especially true if the transmission isn't vented. Heat causes expansion, excessive expansion causes premature oil/grease seal failure.
//greg//
/ Rhino Gear Box Lube? #4
The Grease you need is EP-00. Do not use cotton spindle or corn head grease unless it has the EP additive. The EP grease is available in 3 grades 0-00-000. You can mix them and any of the 3 would be fine for your cutter. If you can not find this grease go to a Snapper lawn mower dealer. The rear engine riders use EP-00 in their transmission. You can purchase it from a Snapper dealer by the quart.
/ Rhino Gear Box Lube? #5
ive also heard 00 is about the consistency as (axle) grease and 80-90wt gear oil mixed 1:1
/ Rhino Gear Box Lube? #6
Unless you are in a situation where you have no choice to finish the job, do not mix gear oil with EP-00 grease.
