Rhino finish mower made in italy
   / Rhino finish mower made in italy #1
backwaterdogs
peoria, il
jd 4020
I just got a used 7ft finish mower is a rhino, made italy??.
Manual say oil should be AGIP-ENI BLASIA 150
Any idea what this means and what equivalent would be? Ty
   / Rhino finish mower made in italy #3
   / Rhino finish mower made in italy #4
MOBILGEAR 600 XP 150
willy
thanks all.
willy, are you saying mobile gear will work and is compatible?
   / Rhino finish mower made in italy #6
My FM72 6 ft Rhino rear 3 pt finish mower calls for 000 grease for the gearbox.
   / Rhino finish mower made in italy #7
What do you run in all your other gear boxes? Use that.
   / Rhino finish mower made in italy #8
If bought used, maybe contact the seller and ask what oil he was using? Being used you have no assurance that the recommended oil was used. Might not be a bad idea to pull it all out and start fresh with the oil of your choice.
   / Rhino finish mower made in italy #9
It's just a simple gearbox I would use gear oil either 90wt or 140 wt, which ever you prefer. Me personally I run cornhead or 00 grease in all my gearboxes, never had an issue and all are quite happy.
fwiw, I called Rhino Ag, they buy these gear boxes from Italy, but come empty and then they put in 85/140 gear oil (lucas red).
So, i'll put in some 85/140. I bought this used from a guy that bought it from an auction to re-sell, so no idea what the owner put in, am going to change.
So, just in case someone comes across a rhino mower that was made in italy, Rhino puts in Lucas red 85/140 gear oil, regardless what the manual says. thanks all!
New/Unused 2025 H12R Mini Excavator (A51573)
New/Unused 2025...
2014 Dodge Grand Caravan SE Van (A51694)
2014 Dodge Grand...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2014 Ford Escape (MPV), VIN # 1FMCU0JX0EUB93016 (A51572)
2014 Ford Escape...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
