Rhino 224 rebuild
   / Rhino 224 rebuild #1
Tbrendal
Alberton
Rhino 224
First off hello to all! What a great resource, I'm glad to have finally found it.
Well here it goes guys, I have a Rhino 224 aka Jinma tractor that I spun a rod bearing on. I ordered a new sleeve, piston, bearings, for the one bad cylinder from the guys at Farm Boys tractors. Put it all together and noticed after torquing the rod bolts that my crankshaft is shot!
So I guess I'm splitting the tractor and doing a complete rebuild. Was helping that I might get some pointers on splitting the tractor and anything that might make the job easier. Thanks in advance to all!!!:D
   / Rhino 224 rebuild #2
Tbrendal, unfortunately I am of little help in this area but I wanted to post so I can subscribe. I look forward to following your rebuild take lots of pics :)
   / Rhino 224 rebuild #3
Curious why it turned out the crank was bad after the fact. I'm assuming you inspected and mic'd all the crank bearings and journals before you ordered parts?
   / Rhino 224 rebuild
I didn't measure the crank rod journal as the bearing's only come in one size(that I know of). Was hoping for the best kinda thing. Saving my pennies for a new crank and plan on the rebuild soon.
   / Rhino 224 rebuild #5
More often than not crank journal bearings are interchangeable dimensionwise with other brands. Example: Your bearings may be identical to Kubota or Yanmar diesels, in which case there would be oversize bearings available. A good parts person can do this for you or you can also check with Clevite and Monmouth bearing companies, which manufacture OEM branded bearing inserts.
2025 K731G UNUSED Flower Bed (A53117)
2025 K731G UNUSED...
2024 Bison Tek Skid Loader BT360 (A52384)
2024 Bison Tek...
2011 Nissan Juke SUV (A51694)
2011 Nissan Juke...
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
1985 International 1754 Material Spreader Dump Truck (A51691)
1985 International...
