Rhino 224 rebuild
   / Rhino 224 rebuild #1
Tbrendal
Alberton
Rhino 224
First off hello to all! What a great resource, I'm glad to have finally found it.
Well here it goes guys, I have a Rhino 224 aka Jinma tractor that I spun a rod bearing on. I ordered a new sleeve, piston, bearings, for the one bad cylinder from the guys at Farm Boys tractors. Put it all together and noticed after torquing the rod bolts that my crankshaft is shot!
So I guess I'm splitting the tractor and doing a complete rebuild. Was helping that I might get some pointers on splitting the tractor and anything that might make the job easier. Thanks in advance to all!!!:D
   / Rhino 224 rebuild #2
Tbrendal, unfortunately I am of little help in this area but I wanted to post so I can subscribe. I look forward to following your rebuild take lots of pics :)
   / Rhino 224 rebuild #3
Curious why it turned out the crank was bad after the fact. I'm assuming you inspected and mic'd all the crank bearings and journals before you ordered parts?
   / Rhino 224 rebuild
I didn't measure the crank rod journal as the bearing's only come in one size(that I know of). Was hoping for the best kinda thing. Saving my pennies for a new crank and plan on the rebuild soon.
   / Rhino 224 rebuild #5
More often than not crank journal bearings are interchangeable dimensionwise with other brands. Example: Your bearings may be identical to Kubota or Yanmar diesels, in which case there would be oversize bearings available. A good parts person can do this for you or you can also check with Clevite and Monmouth bearing companies, which manufacture OEM branded bearing inserts.
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A53473)
2015 RAM 5500...
2017 Ford Taurus Sedan (A51694)
2017 Ford Taurus...
Electric Mobility Scooter (A51694)
Electric Mobility...
2005 International 4200 VT365, Super Cab (A52384)
2005 International...
FAKE (A52472)
FAKE (A52472)
