Rhino 172 pto drive shaft is shot
   / Rhino 172 pto drive shaft is shot #1
MontanaMan406
TYM T754
Just purchased a used Rhino 172, 6’ wide rotary cutter for my tractor. It worked on the sellers tractor but when i got it home, the driftshaft connection spring was off and it will not expand or contract.
It has Comer T40 4004 on it.
Is this an easily replaceable part? Other suggestions? It is my first rotary cutter 👍🏻
   / Rhino 172 pto drive shaft is shot #2
Do you have both halves of the pto shaft? Can they adjust (slide) for length? Will the one end attach to the tractor's pto shaft?
It will not expand (or contract). I have the entire thing.
If it would expand, I could “try” to pull the spring back if it’d slide in the spline.
With that said. I would prefer to fix it so it is in proper working order. Don’t need it ruining the tractor or anything like that.
   / Rhino 172 pto drive shaft is shot #6
UNUSED FUTURE ECA63 ARTICULATED BRUSH CUTTER (A51248)
UNUSED FUTURE...
JD 1814E LOT IDENTIFIER 264 (A53084)
JD 1814E LOT...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
(3) STEEL CARTS W/ WHEELS (A51248)
(3) STEEL CARTS W/...
KISMILE HBZB-30N ELECTRIC ICE MAKER (A51248)
KISMILE HBZB-30N...
UNUSED CFG HANG-ON PALLET FORKS (A51248)
UNUSED CFG HANG-ON...
